Country Clipper thoughts?
   / Country Clipper thoughts? #14
Saw the BadBoy mower w/60" deck for $4995, at TSC even had one at another TSC marked down to $4495, don't know anything about them, but had a welded deck and B&S engine. Good looking mower for that kind of money.
   / Country Clipper thoughts? #15
There are several different Hustler models. Mine is just the 36" that does some small stuff and my roadside ditch, It is a consumer model and will last many years for the amt of mowing I do with it.
I drove a 54" mini Z a friend of mine has and it was simular to my 61" Grasshopper whereas you can feel the quality of a commercial grade mower.
Keep looking Eddie you will find something you like.
   / Country Clipper thoughts? #16
I have a 48" zero radius joystick controlled Country Clipper mower. It has a Kohler motor. It has been a rock solid performer for us. We have about 200 hrs on the mower I think. Seems very well built with plenty of grease fittings throughout. This one has belts for the hydraulic wheel motors and shaft drive to the deck.
I did have some trouble with the factory fuse holders/fuses. No big deal, I just swapped em out. The disc brake linkage(s) seem to work loose over time so keep an eye on that. Other than those two things, we just change the oil every spring, grease all the fittings, clean the air filter, and mow.
   / Country Clipper thoughts? #17
I would like to pass on to you my experience with CountryClipper. I purchased a Jazzee II about four years ago. The first time I used it (cutting 3 acres of centipede grass, flat, no rocks) the deck belt came off. I was able to put it back on, however, about the fourth time I used it the belt slung and was chewed up. I had to replace it at $60.00. The following summer, I was able to cut grass several times without the deck belt coming off. But as luck would have it, this was short lived. The belt came off and could not be reused. I took the mower back to my dealer in an effort to get this problem fixed. They called after three days and said it was fixed and ready to pickup. I picked it up, used it two times before the belt came off again. I called to take the mower back to the dealer only to discover they were no longer dealers for CountryClipper. Now I have a $5400 mower, one dealer located two hours from my home, and no place to buy parts! I am unable to use it at this time.
I contacted CountryClipper via email. One week later, a representative from their company called me. He informed me that I was not a registered owner in their database. He said the dealer was supposed to register the mower in my name and evidently it was never done. He also indicated that CountryClipper did have a problem with the pulleys that originally came on the mower. This was why the deck belts would not stay on. He also told me they now have a kit that replaces the old pulleys with a different type. This supposedly corrects the problem. He indicated they might not be able to give me the kit. I told him I would buy the kit. It would be cheaper in the end for me since I would not have to buy 3 to 4 belts per cutting season. The gentleman with CountryClipper told me he would look into the matter and call me back. I never heard back from him. A week later I called him back. He did not remember even talking to me! I refreshed his memory about our conversation and he told me he was sending the kit out to me the following day. He took my mailing address and other info. I finally felt some relief. In a few days I was going to be able to get my $5400 mower working like it was supposed to. Additionally, I felt finally here is a company that will stand behind their product and fix this situation. If my dealer had done what they were required to do, I would already have the kit installed on my mower.
So my advice to you, make sure you buy it from a reputable dealer. The guy I bought mine from had been in business in my community for many years. There was no reason to believe he was anything else!
Lastly, it has been two weeks today since CountryClipper's representative told me he was sending me the kit. I have yet to see it or hear from them. I guess the guy forgot he talked to me again!
Sorry for the long post,
Jim
Thank you everyone for your advice. I've been looking at other brands and I'm not as interested in Country Clipper as I was when I first started this thread. In comparison, some things on it are more residential then what I want for maintaining my land.
Eddie
   / Country Clipper thoughts? #19
A couple of thoughts:
Along the lines of having the deck offset for fence rows. I have a around 800feet of fence row and pine trees that get mowed with an old front mount lesco zero turn rider. It is nice to be able run under the pines and fence in spots with the deck (beats weed wacking). I am not sure if a midmount zero turn would be as useful for the fence mowing and under tree mowing.
Have you thought about a commercial walk behind. Something like this:
Better commercial lawn mower lawn tractor zero turn riding lawn mower.
I've run an old John Deere 48" it is more like work than a ride on but the prices aboutn 1/2.
   / Country Clipper thoughts? #20
Eddie, What did you get? Curious because I got a CC Jazee 1 in JUne.
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
