CountyLine Carryall
/ CountyLine Carryall #21
I noticed at my TSC that the carryalls and the other implements are slowly coming in "quick hitch compatible" The ones that have been in stock are not compatible but the new ones are.
Mine has a sticker that says "Quick Hitch Compatible". Some post I read on here said that even though it has this sticker, it is not compatible...
/ CountyLine Carryall #24
i missed one for sale on the side of the road for $40 a month or 2 ago, it alread had a box built out of 5/4 boards on it with one board wide sides as well. I know a place along i85 between charlotte and spartenburg that the guy sells them for $65 (new). They may be a tad smaller than the one at TSC but i did not pay attention to either.
/ CountyLine Carryall #25
Even though my carryall frame is rated at 1000lbs, I still worry a bit about overloading it. My box will hold over 1/3 cord of wood; when the wood is wet/green hardwood, this can approach the limit of the carryall (especially since the 2X8 framing probably already weighs a couple hundred pounds!).
Maybe the lighter unit would be appropriate if I had a 20 hp tractor, but
I wouldn't even consider the 500lb limit carryall frame for my uses.
BOB
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2021 Bobcat UV34 4x4 Gas Utility Cart (A61572)
2021 Bobcat UV34...
2009 Ford F550 Flatbed w/ Lift Gate (A62613)
2009 Ford F550...
2018 F550 Bucket Truck (A63689)
2018 F550 Bucket...
Adams Tilt Trailer (A63688)
Adams Tilt Trailer...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
