Couple more questions about out LA513 loader
   / Couple more questions about out LA513 loader #21
The following comments are a bit generic and may not apply to a specific model.
I would differ on the Kubota having a main relief valve and then a relief valve in the loader valve.
Look for a label on the Kubota down on the right side where the loader valve connects into the main system. Typically there is a caution label warning not to disconnect the power beyond bypass as the main pump will be destroyed.
If there is no loader, Kubota puts a hose loop to direct the main pump flow to the rear of the tractor where the only relief valve is which controls the 3 pt hitch and rear remote pressures.
When the loader valve is installed, the pb loop is broken, main pump discharge goes to loader valve IN and the loader valve PB connects where the loop previously was to continue to power the rear of the tractor. Now the loader relief valve is the first one in the circuit and limits the max pressure any downstream relief valve can achieve. If you try and adjust the relief pressure for the 3 pt and rear remotes you will soon learn that it will not go above the loader relief valve setting.
The 3rd function is now downstream of the loader valve and while I do not think the 3rd function has a relief valve, even if it did, the loader relief would limit the max pressure.
My caution to owners working on hydraulics is for them to recognize there is no "Lets try it and see what happens."
In milliseconds the main pump is destroyed and expensive components also.
Dave M7040
   / Couple more questions about out LA513 loader #22
Interesting Dave. I understood every valve after the loader would rely on the loader relief but not having a system relief offers no redundancy to protect the pump. The way they went about makes no sense to me. Go figure.
Thanks for all the help and advice. I installed the valve per Land Pride instructions, it is plumbed in on the PB side of the loader valve. Ya"ll really gave me something to think about on adjusting the pressure. I guess I will wait until I can get the grapple mounted on the tractor and see how it handles it. The shims haven't gotten here anyway...lost in the USPS mail...:confused2::laughing:
This is the video that I had seen about adjusting the pressure.
Increasing Hydraulic Pressure Kubota L2501 Tractor - YouTube
   / Couple more questions about out LA513 loader #24
I think that is the smart thing to do. I know I can lift the back wheels off the ground with my bush hog on the back at 2200 psi. So even if I could lift more, I could not move it anywhere. I think you will be happy. Good luck and enjoy!
2011 Nissan Rogue SUV (A50324)
2011 Nissan Rogue...
2015 Ford F-750 Box Truck, VIN # 3FRNF7FA8FV745627 (A51572)
2015 Ford F-750...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
