Craftsman/Husqvarna/Murray front wheel bushing - What are the zerks for❓
   / Craftsman/Husqvarna/Murray front wheel bushing - What are the zerks for❓ #1
65gtotrips
Craftsman GT6000
Hiya,
I have a Craftsman GT6000, which is just like many riding mowers with the 3/4” front spindles.
— My question is: What are the front rim zerks for, as the rims merely use bushings not bearings❓
— Both the outer and inner races are closed with the huge flat washers, and it appears to me that if I do grease the zerks, it won’t do anything.
— I usually just grease the spindle by hand, without using the zerks, because the rim rides on the spindle.
— Again, it doesn’t appear that the grease could even get out of the bushings…
— Is the zerk just there incase the bushings are replaced by bearings, or does the grease exit the inner washer face somehow❓
— Again, the rim rests on the fixed bushings and the bushings don’t spin freely, so I just don’t think that using the zerks will accomplish anything.
Your thoughts are greatly appreciated 👍
Hiya,
Never mind, I figured it out…The zerk tap on the inner raceway of the rim was painted over and the threaded hole wasn’t visible. Just punched it through with a pick and voila❗
   / Craftsman/Husqvarna/Murray front wheel bushing - What are the zerks for❓ #3
You can easily replace the bushings with a bearing. I scored a set on eBay. That's four bearings.
   / Craftsman/Husqvarna/Murray front wheel bushing - What are the zerks for❓ #4
Grease them even if you have to remove the wheels to do it, but keep the wheel hub caps on or dirt will grind everything to bits.
   / Craftsman/Husqvarna/Murray front wheel bushing - What are the zerks for❓ #5
the greasing works, it reduces friction, i replaced tires on a 20 year old mower last summer, it had bushings, which i greased every season, the grease was all over the bushings and spindles, both looked as new as the day they were made.
2019 Dodge Journey Crossroad SUV (A55758)
2019 Dodge Journey...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2017 CHEVROLET SILVERADO 2500HD (A55745)
2017 CHEVROLET...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
