Crank Lift Arm Leveling Assembly
   / Crank Lift Arm Leveling Assembly #1
Dog Gone It
TN.
L2501 (4wd)
   / Crank Lift Arm Leveling Assembly #2
That one looks good. Will it fit your tractor ? Kinda expensive tho.....maybe a farm auction place will have something.
Good Luck.
   / Crank Lift Arm Leveling Assembly #3
I too had a hand crank leveling arm. It was on a 1964 David Brown 880.
Could easily adjust from the operators seat.
I have found several folks that make them. Here is a link to one.
Not sure this will fit yours though.
https://www.steinertractor.com/FDS0...MIibicgYfY1gIVAQ5pCh2guQnDEAQYAiABEgI6YPD_BwE
Try googling "lft arm leveling" or some variation thereoff.
If you have a rear remote, you can get them that operate hydraulically.
Thanks for the help.
Maybe they will make something that doesnt need to be modified.
Im fine with standard but I really like the crank handle.
   / Crank Lift Arm Leveling Assembly #5
The Grand L Kubotas come equipped with one of those, so they should be available from a Kub dealer. Probably not cheap. Kubota 3 point hardware also shows up on Ebay pretty often. My L4610 had one and it was very handy.
   / Crank Lift Arm Leveling Assembly #6
I just priced out the crank style leveling box from one of the older grand L kubotas to use on my new L3901 and the dealer priced it out at $571!!!!! Crazy money considering all the others I have found were around $100 give or take.
   / Crank Lift Arm Leveling Assembly #7
Some tractor salvage yards accumulate old Kubota hulks and sell used parts like this online much cheaper than new. Keep checking Ebay, etc., if it's not there the first time you look.
   / Crank Lift Arm Leveling Assembly #8
For $571 you could have a hydraulic side link. Well... almost.
   / Crank Lift Arm Leveling Assembly #9
If he has the rear remote, then it would be less than $571.
$400 for the side link.
$55 for the hose kit.
$15 for the flow restrictors.
??? UPS shipping costs. (probably around $40)
Just comes down to what a person wants. ;)
I wont be having a rear remote but thanks for the idea.
Thanks for all the other great ideas as well.
Maybe something will come along in time.
2015 KENWORTH T680 SLEEPER (A59575)
2015 KENWORTH T680...
Deere 310L (A53317)
Deere 310L (A53317)
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A57453)
2006 GMC W3500...
1992 22ft Bayliner BYQ Boat w/ ASPT T/A Boat Trailer (A56859)
1992 22ft Bayliner...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
Simpson 3400 PSI Pressure Washer (A57453)
Simpson 3400 PSI...
