Crank Seal
   / Crank Seal #1
Fornshell
Bronze Member
JD2240
Can you install a JD 2240 Crank seal without special tool.
   / Crank Seal #2
It looks like it is similar to this seal replacement video and I think it would be tough to do it without the tool. The seal must push in hard because it is a press fit in the block and on the crank and it must be installed straight.
   / Crank Seal
Yes I watched that video. Expensive tool for one install.
   / Crank Seal #4
There are a bunch of non-deere seal installers sold online. Will a shop loan/rent one to you?
   / Crank Seal
Ok thanks I'll look online.
   / Crank Seal #6
You can partially install it using the flywheel. Then you know it goes on straight. You'll have to tap it the rest of the way in though. If you're careful you can get it in there without getting it cockeyed.
Alternatively if you have access to a lathe you can make your own
   / Crank Seal
Thanks for your help,that's kinda what I had in mind using the flywheel.
   / Crank Seal
Ok thanks for the information, will look it up
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
Woods 3180 Batwing Mower (A59814)
Woods 3180 Batwing...
1660 (A59213)
1660 (A59213)
