Creating an Entrance
   / Creating an Entrance #21
Great pictorial and a neat project!!
Great pics!!
What's the sign gonna say? Inquiring minds ya know... /forums/images/graemlins/laugh.gif
   / Creating an Entrance #22
Here's a night shot of my entrance. Gerard
   / Creating an Entrance #23
No flash. Gerard
   / Creating an Entrance #24
That is a fine looking entrance. Stone pillars are so visually appealing. They give a sense of quality and permanance to the property. Very nice design too. Thanks for the photographs of the building process.
Cliff
   / Creating an Entrance #25
Eddie, Very nice look and a lot of work but it does give you a sense of accomplishment and satisfaction when its all done!
Too bad about the big tree ,I also lost a big tree that would give shade to to my house and barn till 10:30-11am and I miss it, It kept the place cooler a little longer.
Can't wait to see the rest of the project!! hint hint /forums/images/graemlins/wink.gif
This morning I started to build my form for the cap.
First was to cut a 2 foot square piece of 3/4 plywood that I had lying around.
Then I figured a 2X6 would give me enough height to create the pyramid look.
I thought I had some masonite scrap lying around, but remembered when I was looking for it that I burned it in my last clean up day. Oops.
I did have some luan, which I figured I can work with.
I measured out a flat spot in the middle to mount a light to and cut the luan 2 feet wide by 10 1/2 inches. This gave me an appealing slope for the pyramid look.
The columns are 21 inches wide with the rock on them, so the caps should overhand 1 1/2 inches all around.
The angle came out to 19 degrees on my chop saw.
The other two pieces just needed the corners cut off at 45 degrees and then sanded down to fit flush.
I glued and screwed the main pieces together, but the luan was glued and stapled.
The form is togther, but I decided to use silicone to seal the edges and round the inside corners off. Then I used it to fill the staple holes and just ended up coating all of the luan with silicone.
I started worrying that the luan would fall apart from the moisture in the morter. Now I'll have a rough finish.
I will just have to wait and see how it turns out.
I let the form dry for a couple hours, then mixed my mud.
I used a premix sack of Type N morter that I have left over from attaching the rocks to the columns. I added two plastic cup fulls of Portland Cement and half a bottle of Charcoal die.
This mix is a result from advice I recieved on another thread called coloring cement.
I mixed half of the 60 pound sack and put it in kind of wet. Then I layed half inch, 19 guage, galvanized fenceing down.
Then I mixed the rest of the morter and added two more cups of cement to it. I put this in a little dryer to help hold it all together on the edges.
In the middle I placed a piece of 3/4 inch pvc to run my wire through when I install the cap.
The picture shows the hollow middle. I could have mixed another sack to fill it up, but I don't think I needed it. This is one full 60 pound sack.
I'm guessing I have about $10 into the cap, not counting lumber.
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
Case 1020 25ft Draper Head (A56436)
Case 1020 25ft...
2003 Ford Pressure Digger Truck (A55973)
2003 Ford Pressure...
2008 Ford E-350 Versalift 29N 29ft Bucket Van (A56858)
2008 Ford E-350...
