y
creek water for domestic use, any ideas?
   / creek water for domestic use, any ideas? #41
Tank is half below ground/half above ground with a lift off lid.
mark
What is the Manufacturer HP,Voltage, Full Load Amps, GPM and Head/Pressure design of the pump? I am wondering if you might have a voltage drop issue.
Nope I am almost positive that I have a bad splice. I have power on one wire and not the other. I cannot recall the exact specs on the pump ( I am at work right now) but it is a deep well pump so pumping the water up 80 ft or so shouldn't be an issue I wouldn't think. It came out of a 350ft well.
   / creek water for domestic use, any ideas? #43
I have a well that is basically creek water. It is three 3' culvert sections sunk vertically in the ground, and is about 17' deep, 10' away from the edge of the creek. The creek water filters through the sand and gravel layer, which keeps mud out of the system when the water is high and muddy. I use a shallow well pump, and a 1", 1 micron paper cartridge filter on the line to remove the occasional fine silt that gets through the gravel. I have to change the filter about twice a year.
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A60429)
2021 CATERPILLAR...
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
2005 INGERSOLL RAND WL-440 WHEEL LOADER (A60429)
2005 INGERSOLL...
