CurlyDave
Elite Member
I need to cross a winter creek with a 120 volt electric line.
The basic question is do I go over it, or under it?
The stream bed is 10-12 feet wide and at some times the water is 12" or so deep.
I can burry a plastic conduit up to about 6' deep if necessary, but I worry about any small leak causing it to fill with water.
Another possibility is to erect two poles and cross with an overhead line.
I also have some spare 20' sections of 6" steel well casing. I could cross with one of these with a vault at either end and run plastic conduit inside the steel casing. I would go underground to the two vaults. This actully seems like the safest and best way to me, but I also think it is totally non-standard and would not meet any building code known to western civilization. The steel well casing would be about 12" above the high water line.
Any other ideas? Direct burial cable?
Suggestions for which way to go?
