Cruise Control BX2200
   / Cruise Control BX2200 #11
Here are the instructions
   / Cruise Control BX2200 #12
Do you think that there is enough room in the slot for the seat belt and the cruise control? I am thinking of it for the BX 22, but Kubota doesn't recommend this because of the seat belt.
   / Cruise Control BX2200 #13
Paul,
Are you talking about the slot where the lever goes?
If it is just a belt I think it would because the spring pulls the lever back when You hit the brake lever or travel pedal.
You have to move the lever forward with Your foot depressing the travel pedal.
It stays locked until either the brake pedal or travel pedal is moved.
All the cruise control is a mechanical means of locking the travel pedal in position.
I took some pics of mine and will try to post them as soon as I get them developed as I do not have a digital camera.
   / Cruise Control BX2200 #14
Well Paul I have some pics for You.....Not the best quality as they were taken with a throw-away camera.
Attached is a pic of what comes in the kit. /forums/images/graemlins/grin.gif
   / Cruise Control BX2200 #15
Here is one of the view with the right rear wheel off
   / Cruise Control BX2200 #16
View with bracket and lever installed
   / Cruise Control BX2200 #17
fuel pump with bracket attached(new bracket)
   / Cruise Control BX2200 #18
other end of bracket
   / Cruise Control BX2200 #19
Locking dogs installed
   / Cruise Control BX2200 #20
Rod that has to be 350 mm installed
Unused 2025 CFG MX12RX Mini Excavator (A50322)
Unused 2025 CFG...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
8ft x 6ft Container with Side Door (A51573)
8ft x 6ft...
2009 Dodge Ram Utility Pickup Truck, VIN # 3D6WC78L09G558300 (A51572)
2009 Dodge Ram...
2005 Ford F150 XL Triton (A50120)
2005 Ford F150 XL...
Toro Workman Utility Cart (A51694)
Toro Workman...
