Ct 230 won't stay running
   / Ct 230 won't stay running #1
firewood cutter
Bobcat ct230
I have 2011, 12 bobcat ct230 that starts, runs for a short time and then the fuel solenoid kicks out. The solenoid is new and I've checked all the relays and fuses.
   / Ct 230 won't stay running #2
With only that to work on, I suspect a bad ground. Check that your battery's negative cable connections are clean. If it's not grounded to the engine block, make it so.
   / Ct 230 won't stay running #3
Fuel solenoid is what kills it when you turn the key off. I would sort of suspect one of the safety switches. Does it crank back up after dying?
I checked safety switches and the ground is at the battery. It's gotta be something simple I'm missing.
   / Ct 230 won't stay running #5
You check the seat presence switch? Kills the engine when you lift up a bit. Might need to put a jumper on it.
Yep, I put a bypass jumper wire on it when I first got it, never been a problem. Did try reconnecting it and sitting in the seat. Either way has no affect.
I can take the solenoid out and run it all day, I just can't shut it off with the key then. All other lights and gauges work as normal.
   / Ct 230 won't stay running #8
Asking again, does it crank right back up after dying or what is the time involved before cranking again?
Yep it will start right back up after I turn the key off and the solenoid resets, about 10 seconds.
I also took the 2 screws out that hold the fuse panel in place and looked for a broken wire or exposed bare wire, that all looks good.
Miller Millermatic CP/CC-1500 Industrial Welder  Heavy-Duty Power Source (A59225)
Miller Millermatic...
SKID STEER BUCKET (A58216)
SKID STEER BUCKET...
AGRI X 6' ROTARY MOWER (A58375)
AGRI X 6' ROTARY...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59575)
2004 INTERNATIONAL...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
