Cub Cadet 2186 and 3165
   / Cub Cadet 2186 and 3165 #1
RCT
Raleigh, NC
Cub Cadet 2138
In anticipation of next month's bonus I stopped by my local Cub dealer. He had 2 tractors that peaked my interest. One was a CC 2186 for $2600 and the other was a 3165 for $4400 with a 44" deck. I had a couple of questions. First, what current models are they equivalent to, and second should I be worried about a tractor that has been sitting out for three years. They have been under one of those big metal carport things. I know the 3165 has a ripped seat (which I will have replaced), but I know that it also has the hydraulic lift system for the deck. Both are new left overs with 0 hours. The 3165 is 3 years old, I don't know how old the 2186 is.
   / Cub Cadet 2186 and 3165 #2
You can probably trust your dealer on this. Plus, if you get a full warrenty your covered. I would try to get the lowest price though. My 2518 was a holdover almost 2 years old and its done ok.
   / Cub Cadet 2186 and 3165 #3
The 2186 was the top of 2000 series thru 2004. I think it had an 18 or 20 hp kohler v twin. I have a 2518 that was introduced in 2003 and the only difference was the 2186 has an aluminum transmission and the 2518 was cast iron. I wanted the 2186 when I bought mine but since it was late in the season when I purchased my tractor my dealer didn't have one. They gave me the 2518 (show room model) instead at the same price.
I am not sure about the 3165.
Both units sound like a great deal. I would make sure they had full warranties before I would make a decision.
Let us know what you decide. :)
Michael
   / Cub Cadet 2186 and 3165 #4
micman32 said:
The 2186 was the top of 2000 series thru 2004. I think it had an 18 or 20 hp kohler v twin...
It's been a while now, but IIRC, I considered buying a leftover 2186 in early 2005. It had a briggs and stratton vanguard series 18hp (top of the line B&S), an aluminum transaxle and a 42" deck. I didn't care for it as the 2005+ have a bit more leg room. That & I prefer the 3 blade 44" over the 2 blade 42". That 2186 would be a steal though if you can get it for $2600 total out the door price. If you want more comfort, weight and capabilty and can pony up the bucks, go for that 3K series!
Joel
Thanks JTKUB. Both had 44" decks. I didn't realize the 2186 had an aluminum tranny though. Is this a concern? Is it still fully serviceable? One of the reasons I was looking at the 2000 series vs the 1000/1500 series was the serviceable tranny. I do all my own auto repairs and wanted to do the same for my tractor. Nothing pissed me off more than to find out that when the tranny went on my Murray after 3 years that I couldn't fix it. No parts, not even the dealers could fix it. It was replace the whole tranny or the tractor. The 2186 had a 20 hp Kohler Command, I don't know what the 3186 had.
   / Cub Cadet 2186 and 3165 #6
Oops, I'm confusing the 2180 with the 2186. Either way, I wouldn't let the aluminum transaxle case sway you. It's still a heavy-duty fully serviceable unit & was used for something like 20yrs. They have a dipstick/fill port, a drain plug and a huge spin-on filter. The 'cast iron' trans cases weigh a bit more, but are more of a marketing gimmick than anything for a small garden tractor application.
Joel
I only have 3/4 of an acre so I am wondering if I can justify the extra $1800 on the 3165. I have done the "its easier to ask forgiveness than permission" many times before, but I think that may be pushing it. I am having a hard enough time talking her into the 2186 at $2600 or $2800 after tax, that's right gotta pay the tax man. With taxes the 3165 would be $4700. She doesn't understand that $200 won't buy anything but a disposable tractor anymore (she must of forgotten the cursing after the Murray fiasco).
   / Cub Cadet 2186 and 3165 #8
I have just under an acre and I have a 2544, which is the model that replaced the 2186. 44" cut, 3 blade deck. Only difference is the cast iron tranny and the reverse disable on the ignition switch, which allows you to mow in reverse. On the 2186, you'll have to 'cheat' the system by disabling the reverse mowing switch on the shift linkage.
IMHO, the cast iron transmission was a marketing gimmick by Cub. The trans housing is cast in China, vs. a die cast aluminum housing made in the USA. Yes, it's cast iron, but it's probably cheaper than the aluminum housing. Nevertheless, the 2544 hydro is a sweet unit. Quiet and has no issues at all.
I've not pulled anything except a 42" core aerator, which it didn't even notice. I rolled the yard this fall, but rented a ride-on roller/compactor. It makes those tow-behind rollers look like a sick joke. My yard was BAD, so even after rolling and aerating, it's merely tolerable.
Anyway, back on topic. Either tractor will be great. If you can swing the 3000 series machine, do it. If not, be totally confident that you'll love the 2186. I almost bought a leftover unit myself, but it got sold before I got to it, so I ended up with an '05 model 2544. It's a real pleasure to use.
Chris
   / Cub Cadet 2186 and 3165 #9
Does the 3165 have a locking rear differential? In the current 3000 models I believe the main difference between the 31xx and the 32xx is a locking rear differential. I suspect you would quickly fall in love w/ the power steering on the 3165.
As for justifying a larger tractor, you can never really have too much tractor can you? I have a 5252 for right at an acre.
While I was shopping for my current tractor I looked at a few 3000 series cubs. I never saw anything as cheap as 4400. That sounds like a great deal.
   / Cub Cadet 2186 and 3165 #10
When I was getting my dad a new tractor I went for the 3000 series, specifically 3204, because of the hydraulic deck lift and steering. Its also a very solid heavy tractor. I'm sure in his case the 2000 series would have done a fine job, but being along in years I felt the power steering was a must.
I think in your case with the 3/4 acre the hydraulics would be the primary reason for going with the 3165, if not too important to you then the 2186 will do a great job and you can use the extra cash for other toys.
2016 Ford Fusion SE Sedan (A59231)
2016 Ford Fusion...
2015 MACK GU713 DUMP TRUCK (A59823)
2015 MACK GU713...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
2023 Chevrolet 1500 Silverado Z71 Crew Cab Pick-Up Truck (A59230)
2023 Chevrolet...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A60429)
(INOP) 2016...
