Cub Cadet 2186 and 3165
   / Cub Cadet 2186 and 3165 #31
RCT said:
So what would I be looking at for a 3100 with a 44" deck out the door??
Your in a good area that should have a few dealers to give you an idea...the short answer is not much more than what you were quoted for an old machine..IMHO
Posted is a link for reference - I suspect you will fair better than that
Cub Cadet
   / Cub Cadet 2186 and 3165 #32
ducati996 said:
Im not really believing the website as accurate because I know the 44" deck for the 2544 is less than 140lbs of the 3000 series 44" which is 140lbs....
If I was to venture a guess, I'd say my 44" weighs 100lbs tops. Probably somewhere between 80-100lbs. As far as the tractor goes? I have no idea.
Joel
   / Cub Cadet 2186 and 3165 #33
Joel
Im pretty sure they didnt change the deck design on the 2006 models....
Makes me wonder how accurate the website is even more, unless one of the dealers can tell me the 2006 are significantly more heavier than the 2005's...
They didnt change the frame or the drive train - so where did the extra weight go to? Thats a big difference from the 2500 series of 2005 and earlier being at 520 < lbs, to a machine that supposedly now weighs 700 lbs? Im not convinced this is the case at all, but I could be wrong. I have seem time up close, and it didnt strike me as a heavier unit.
Duc
   / Cub Cadet 2186 and 3165 #34
Now that I think about it (and had to shove it around the garage today), I would be surprized if my 2544 exceeded 600lbs, deck and all.
Joel
   / Cub Cadet 2186 and 3165 #35
Joel
Thanks for that info - Its where I based my info regarding the weight difference between the two machines in the past - and if indeed the 2006 series weigh alot more than, I stand corrected :) Im just now confused :)
Ok, so I/we have decided on the 2186 or a new 2544. Any reason to choose one over the other. I am not worried about the no mow in reverse, I can fix that.
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
2024 CATERPILLAR 306CR EXCAVATOR (A60429)
2024 CATERPILLAR...
