cub cadet 7235 starting problem
   / cub cadet 7235 starting problem #1
powerstf
While snowblowing my cub cadet 7235 suddenly started racing as if the the throttle was stuck then immediately stopped running. Since it has been frigid temps, I've changed the filter, bled the fuel lines, checked the fuel pump but the motor turns over but will not start. Has anyone had a similar issue? Thanks
   / cub cadet 7235 starting problem #2
Have you checked for icing in the air filter?
Jim
Thanks for replying Jim. I hadn't done that. I just went and checked and there is no icing. Tim
   / cub cadet 7235 starting problem #4
Sounds like the injection pump is giving you grief but hopefully it's some thing simple.
   / cub cadet 7235 starting problem #5
Are you sure your fuel is good and not gelling? Fuel solenoid working properly? How many hours on the rig? What had you been doing when it acted up?
Jim
Jim
I was snowblowing at the time. Really light fluffy snow when the motor just revved up and then the tractor stalled. I changed out the filter changed the fuel and chased the fuel line all the way to the fuel injector pump. Still nothing.
2016 Ford E-350 Econoline Cutaway Service Van (A46683)
2016 Ford E-350...
2017 Ford F-650 14ft Mason Dump Truck (A46683)
2017 Ford F-650...
Case International 1896 2WD Tractor (A49251)
Case International...
Galvanized Panels (A49339)
Galvanized Panels...
2016 RANCO ANVIL END DUMP EDQ 20-26 (A48992)
2016 RANCO ANVIL...
Easy Flo 220 Bushel Gravity Wagon (A49251)
Easy Flo 220...
