cub cadet starting problem
/ cub cadet starting problem #1
pjh008
augusta,ks
cub cadet 1045
Hi everybody, first time question. Cub cadet 1045 with 20hp Kohler courage engine. When starting it will only turn until it is under compression and stops. Got a new battery that has been double checked, it's good. I've looked over the wiring tried jump starting off my truck battery, no good. Pulled the spark plug and it turns over fine. Just can't get over that compression hump, any ideas ?
/ cub cadet starting problem #2
Have you checked your valve settings? If they are too loose then you will build compression in the cylinder. I had the same problem with a B&S once I set the valves it turned over like new
Terry
Thank brother, i'll check it out. It would be nice if I had a service manual for this. The engine is a mod#SV690. Don't think they make them anymore. I've tried looking for one with no luck.
Thanks for the manual link, much appreciated !
O.K. Took a look at the valves and adjustments, none needed. Next step, I thought i'd check the flywheel key to see if that maybe damaged. If it is , wouldn't that throw off the timing to where it would cause this to happen. What about going with a higher cold crank amps on the battery? This one really has me stumped.
/ cub cadet starting problem #7
I have a CC1050 with the 23hp Kohler motor. I too have starting trouble. I replaced my battery, air filter,& plugs this year trying to remedy the problem. What made the most difference though, was changing the in-line fuel filter. It only struggles a bit when I first fire it up but not nearly as much as it did before.
/ cub cadet starting problem #8
I have a lawn tractor that was like that. The cylinder was loading up with gas while parked. I fixed it with a fuel shut-off valve that I close when it's parked. I know the problem I is in the carb, but I didn't want to take it apart.
/ cub cadet starting problem #9
The only thing I see that wasn't covered...........is the starter weak?
/ cub cadet starting problem #10
I am not sure about the 2 cyl Kohlers but the single cyl has a set of advance weights on the cam gear. This retards the cam for cranking and when the engine starts the weights advance the cam. If these are stuck it will crank over verry hard. On my 16 hp you could get to the weights without dissassembling the engine. There is a cover you could remove and with a can of brake clean with a nozzel you could clean it. Hope this helps.
Bill
/ cub cadet starting problem #11
Is it doing this when hot? If so, it could be the windings in the starter getting too hot to run. Or the engine getting too hot and binding.
Pressure wash the engine behind the metal covers to clean the cylinder and head cooling fins.
/ cub cadet starting problem #12
I just went through the service manual and if you go in the trouble shooting section to hard starting. They say you could have a faulty ACR (automatic crank ******) They don't show a pic or give any info on how to service it. go here http://www.kohlerengines.com/onlinecatalog/pdf/tp_2548_a.pdf on page 81 they have pics and a good explanation of how the ACR works.
Bill
/ cub cadet starting problem #13
I'm having same problem. That Service Manual doesn't look exactly like my 22 HP Koehler... mine has a compartment on top for air filter. Also, don't see any thing about how to SERVICE the ACR. Will keep searching. My starting issue definitely seems like a COMPRESSION PROBLEM. It turns over about a quarter turn, then compression stops it from going further. After about 10 key turns, will eventually overcome the compression, and start. It's only 6 months old. 30 hours on motor. Already done first change on oil.
/ cub cadet starting problem #14
Hi Merlin777, My briggs 15.5 hp motor also battled to start.I reset the valve clearances and now starts first time and is running like a new one.
Ray
/ cub cadet starting problem #15
If its only 6 months old and 30 hours it would go back to the dealer and let them deal with the problem.
/ cub cadet starting problem #16
Yes... will do that... And, I have the extended warranty, and they will pick it up at the house. The nuisance is, I work long days and SCHEDUELING the pickup and return will be a problem.... Was hoping it might be something others are experiencing, and that would be (relatively) easy to adjust myself.....
/ cub cadet starting problem #17
I have a cub-cadet with a kohler sv730s has new battery, starter, solenoid and it still drags when you try to start it.
1967 Hyster Equipment Trailer (A66285)
1967 Hyster...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
40' New Container (A62679)
40' New Container...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
John Deere 8320R (A64126)
John Deere 8320R...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
