Cub Cadet trans/hydraulic filter
   / Cub Cadet trans/hydraulic filter #1
Plazmadart
cub cadet 7360ss
Members,
I have a Cub Cadet 7360SS. I went into shock when I tried to buy a trans/hydraulic filter for the 200 hr. oil change. Does anyone know of a reasonably priced substitute that will work with this tractor. I would sure appreciate a number that will cross reference. Any information will be appreciated. Farming is getting impossible. The CC part no. is MA-10312518000. Thanks!
   / Cub Cadet trans/hydraulic filter #2
Take the hit. Most hydro-trans filters need to take some serious pressure
   / Cub Cadet trans/hydraulic filter #3
Your gonna have to buy it from the dealer for a while, you can't cross that number cause the manufacture holds the patent for usually a year or so. Then you can buy it at napa.
Thank you for the info. I think that is what I will have to do!!!
   / Cub Cadet trans/hydraulic filter #6
Give Baldwin a try Baldwin Filters | Home , On a cheaper scale :) hydro filters for my Bolens were around $20, I found proper hydro filters from Baldwin for $3.50 a pop. Drop 'em a line, you've got nothing to lose....Mike
I want to thank everone who replyed to my Thread. I ended up purchasing a filter from CC. Equipment is just expensive these days. Thanks again for all the info.
   / Cub Cadet trans/hydraulic filter #8
It's astounding how much goes in to keeping these things going sometimes.:( But the alternative is worse!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Kubota M7-151 Premium MFWD Tractor (A56438)
2017 Kubota M7-151...
Komatsu PC220LC Excavator (A59814)
Komatsu PC220LC...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
Caterpillar 906M (A53317)
Caterpillar 906M...
