cub won't stay running
   / cub won't stay running #1
kens41
hope someone can help my cub 3184 won't stay running it starts right up then dies, seems to be fuel related I can squirt gas down the carb and it stays running until I stop. the gas is fresh I took the carb off and cleaned it out that didn't help I'm lost there is a small solenoid device at the base of the carb don't know what that is plugs aren't the greatest but I don't think that is problem any help would be appreciated.
thanks Ken
I took the filter off and blew through it fairly easy, quess I could try a new one thanks
   / cub won't stay running #4
How about the main jet? Have you cleaned out the jet? That will cause it to start and then stall right away.
   / cub won't stay running #5
I suppose it wouldn't hurt to check the little vent in the gas cap. and maybe disconnect fuel hose at tank and carb to blow compressed air through it. If you're nimble you can leave the hose right there where it lays...just disconnect is all.
I'ved tried everything the seems to be spotless after cleaning the filter changed gas lines blowed out don't know what to try next it does run for about 5 seconds at idle then dies, anyone know of anything else to try?
thanks for all the help. ken
   / cub won't stay running #7
Try hooking up a different fuel supply. When I'm troubleshooting a fuel problem the first thing I do is hook up a gravity feed fuel supply. I have a old gas tank off a push mower just for this but you can use anything that you can hook a 1/4" fuel line to. I used to use a empty gear oil bottle with the tapered cap stuck into the fuel line. Hook your new fuel supply directly to the line going to the carb and see if it will stay running. If it does connect it to the fuel filter inlet and just keep working your way back to the tank and you'll find where the restriction is. If it doesn't run with it connected direct to the carb then ether the fuel shutoff solenoid isn't working or if it has a needle and seat it might be stuck. If it doesn't run with it hooked to the fuel filter then I change the fuel pump.
thanks I will try that tomorrow
tried hooking up a seperate fuel fuel tank that didn't help, the solenoid on the carb is working I was wondering could it be an inigtion switch problem?
ken
   / cub won't stay running #10
Can you keep engine running on choke?..check see if choke stay open.
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
2017 KENWORTH T370 SERVICE TRUCK (A51406)
2017 KENWORTH T370...
