cultipacker operating question
/ cultipacker operating question #1
yukonhunter
leroy ny
John deere 5100m, mf1643 cab and kubota bx2370woods bb720x land pride disc and reverse tiller
This may sound dumb, but is it ok to turn while operating a pull type cultipacker? Ill be using it in a food plot and will have to make turns
/ cultipacker operating question #2
yes try not to real sharp
/ cultipacker operating question #3
Assuming this is a pull type,yes. If (3 pt) mounted no.
Terry
/ cultipacker operating question #4
If you have a Three Point Hitch mounted Cultipacker, try to lift it before making sharp turns.
Otherwise, all the wheels in the soil resist sharp turns, putting great strain on both the tractor's Three Point Hitch and Cultipacker mounting points.
Gentle turns are OK.
Its the pull type
/ cultipacker operating question #6
Sure--make wide turns.
I've seen some cultipackers that have hydraulically operated transport wheels that are used to move it over roads from field to field. If so, you can use the hydraulics to raise and lower the cultipacker while making turns.
Good luck.
Freightliner Tender Truck - Adams Tender (A63118)
Freightliner...
John Deere 5075E Tractor w/ John Deere 520M Loader (A64047)
John Deere 5075E...
100 GALLON L SHAPE FUEL TANK (A62131)
100 GALLON L SHAPE...
2005 Sterling Acterra Tender Truck (A63118)
2005 Sterling...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
