culvert heaved
/ culvert heaved #11
</font><font color="blue" class="small">( what you will have to do if it dose not stay down, is to put 2 inches pink or blue styrofoam board 2 feet whide over top of pipe level ground off even top of pipe. cover with ground. works in WI )</font>
That's an interesting trick. I wouldn't have thought insulating the top of the culvert would make a difference, with the ends open to the air. I guess I could see it on a longer culvert, but does it work on a 12 or 15" culvert that's relatively short (i.e. just long enough to cross a driveway)? If so, I may have to try it.
John Mc
/ culvert heaved #12
</font><font color="blue" class="small">( </font><font color="blueclass=small">( what you will have to do if it dose not stay down, is to put 2 inches pink or blue styrofoam board 2 feet whide over top of pipe level ground off even top of pipe. cover with ground. works in WI )</font>
John Mc )</font>
Did you use single or double wall pipe?
/ culvert heaved
I used 12" double wall (smooth inside), with the weep holes facing down (weep holes do not connect with inner surface). Previously there was a steel pipe in place that had weep holes evenly spaced all around (360)...don't know if the weep hoses are a factor.
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
Bell B45E (A60462)
Bell B45E (A60462)
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
2016 Toyota Camry Passenger Car, VIN # 4T1BF1FK4GU249258 (A61569)
2016 Toyota Camry...
1990 TRAIL MASTER  TRANSPORT TRAILER (A60736)
1990 TRAIL MASTER...
