Current on a 12 gauge wire
   / Current on a 12 gauge wire #101
Because I don't want the minimum, I have more circuits than code requires, I want flexibility. I sure as heck don't want a tied breaker just to save 1 cu wire. The cost of not doing shared neutral is small, very small. I know because I bought and installed all the wiring in my house.
   / Current on a 12 gauge wire #102
In this case the cost is pulling two cables or getting 12-4, which is not as common. Those neutrals will tied together at the panel.
I am not against seperating neutrals. But I don't most really know what they are talking about it, and are just going bigger to go bigger. Soon you have a full panel, then you need tandem breakers, which probably upsets you. My house came with some some. Don't bother me, they are just more money. But want to add 240 for air compressor, PIA with so much crap in panel.
It is good to have extra circuits. I like lights seperate so I have them when working on outlets, and if something trips.
NEC is not bare minimum.
Except for a few items, you consume very little power. You are not running things all at once. You can give some cute comeback, my wife and kids... But you are not. There are already margins built into, you are just putting safety on to safety.
I again I am not against putting extra in, I just find most people have no clue what they are talking about, but want something, that they no little about.
   / Current on a 12 gauge wire #103
BI sure as heck don't want a tied breaker just to save 1 cu wire..
We really have no clue what the guy is really doing. Not sure if I would do it that way, and I am not convinced it is being done that way. But I am also not afraid if it either. I have seen small machine screws used between breakers. I'd be tempted to put 4 circuit panel under the island, with local disconnect for dishwasher, if it does not have a plug. But this is way over kill, and really only benifts the electrician and not the home owner. They will probably never touch it, and risk not know it is there if it trips.
But again I ask you why? Do you know, or do you just not like something? You think they are using kite string a twist tie from a bread bag?
   / Current on a 12 gauge wire #104
Guess my clue came after an EE degree in power systems, a PE license, and yrs of designing commercial power systems......Not to mention various NEC courses from NFPA..
   / Current on a 12 gauge wire #105
Are you a pro, or have training? If not, this scares me more than anything else. There is more than just twisting wire nuts. I have taught myself to build engines, but glad I worked as an apprentice in residential wiring. I know work in industrial, and I am not up on all the new codes, but feel safe.
   / Current on a 12 gauge wire #106
Lol, doesn't scare me, and that's all that matters.
   / Current on a 12 gauge wire #107
Curious, around here most home owners do not have 3 phase. Apartments might have it, some farms. But it is very rare for a home to be 3 phase. Guy would have to have a shop of some kind.
I am an industrial electrician by trade. I primarily work on stuff from 500KV down to 12VDC. With 277v three phase wiring, the neutral is shared by the other phases. We work on them hot because a faulty ballast in a ceiling light is repaired without killing the lighting for the entire building floor. All electricians are required to be certified journeymen, or apprentices under a journeyman.
Residential wiring is often modified by well meaning people who may or may not have the necessary skill set. I actually witnessed a 12/2 stripped and taped onto knob and tube to feed an entire second floor of a house, gee, why do the lights flicker???
   / Current on a 12 gauge wire #108
I had a pro, trained electrician on one of my projects who cut into a live 15KV cable. Then there were all those projects where I had to trace out miswired circuits from those trained guys. Just recently I investigated a non working photo cell, discoved they wired a switch to the photo cell hot, instead of the switch wire per instructions.
Not to mention the electrician that told me a timer circuit was 240v, when a visual showed one side tied to neutral, and a meter confirmed 120v.
Yea, I've worked with good ones and bad ones.
   / Current on a 12 gauge wire #109
Quote Originally Posted by GregbkH View Post
BTW, almost all circuits are designed to run at 80% max current. 15 amp breaker = 12 amps, 20 amp breaker = 16 amps.
No. Somewhere people learned a small but of information, but not how to use it.
Continuous load, is for 3 hours. Thae derate.
Standard rated circuit breakers are rated for 80%. The largest continuous load that can be applied to a 60 amp standard breaker and corresponding conductors is 48 amps. Math.... 1.25 (125%) x 48 amps = 60 amps.
They do make 100% duty breakers but they are more expensive.
My statement above was made to help homeowners stay safe.
FWIW, I'm a master electrician and know a thing or two about the NEC and calculations.
   / Current on a 12 gauge wire #110
I am a retired industrial electrician. We used to work on things hot but for the last 10 years our company changed their policy to not working on anything hot. You could get fired if you did and got caught. We also stopped using mwbc's and sharing neutrals. With the increased use of flourescent lighting among other things, the harmonics were putting too much load on the neutrals.
2020 Ford Transit 250 Cargo Van (A51692)
2020 Ford Transit...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
John Deere 848G Grapple Skidder (A52384)
John Deere 848G...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
1998 Jeep Cherokee Sport (A50123)
1998 Jeep Cherokee...
