Custom PTO hookup for Grillo G110
   / Custom PTO hookup for Grillo G110 #1
jcole1989
Grillo G110
I'm interested in being able to hook up my G110 to custom accessories (e.g., generator head and a home-built compost trommel). What's the best (and cheapest) way to acquire a PTO hookup onto which I can attach a pulley of my choosing? Earthtools will sell me a quick coupling for $89, but I can't quite tell from their picture what the implement end terminates in (it's another splined shaft from what I can tell, not a shaft I could mount a pulley on), and Joel offered to sell me an extra of the custom hookups they use for generators and chipper/shredders for about $500 IIRC, but I'm wondering if there's a more economical way for me to do it myself.
   / Custom PTO hookup for Grillo G110 #2
The implement side of the quick connect has a female spline on the implement side.
I ended up buying a couple implement quick connects with a similar idea, but haven't done anything with them. I'll take a picture of the spline this weekend.
I guess you'd need to find a matching spline to go with a shaft so you can add your pulley. I'm assuming it's a standard metric size. If you never want to disassemble it you might just find a shaft which fits and weld it into the spline.
Unless you are a hobby machinist I don't see how you could do any cheaper than the quick connects.
Yes, I didn't mean cheaper than that, but if I go that route it would be nice to know what spline connection I need to attach to the pulley.
@travisbb Any chance you were able to take a picture of the spline?
   / Custom PTO hookup for Grillo G110 #5
Sorry, I got busy this weekend and ran out of time to dig it out. I'm also out of town for a couple of weeks. I've added it to my TODO list for when I return and will definitely do it then.
   / Custom PTO hookup for Grillo G110 #6
Alright, here is a picture of the implement-side quick-connect:
I measure the peak to peak distance as 18.8mm and the trough to trough distance as 15.6mm. The outer diameter is 29.9mm.
For good measure, here is a picture of the tractor-side quick-connect. As expected, this male spline seemed to fit into the implement side female spline perfectly:
I measure the peak to peak distance as 17.6mm and the trough to trough distance as 14.6mm.
I hope that helps. If you discover the name of the standard for such splines I'd be really interested in knowing. It'd make my life easier when I do get around to my custom implements.
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A55787)
2020 Caterpillar...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2016 Peterbilt 567 Tri Axle Dump (A47477)
2016 Peterbilt 567...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
2007 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W97X154872 (A54865)
2007 Ford Crown...
2017 Chevrolet Traverse LS SUV (A55853)
2017 Chevrolet...
