Cut to the Quick
   / Cut to the Quick #1
Davinator
Southern Ohio
Kubota #M6040 w/Grand Cab
I took advantage of the beautiful weather and spent the day at the farm and got some serious seat time. I got to try out the new tiller (LOVED it!) and the the new Pats Easy Change System. I think I will love this too.
But to get the the real reason for starting this thread: I decided to let my dog accompany me on this trip and he got literally trashed with mud! So the first thing when I got home, to avoid divorce court, was to give the Beagle a bath. Well, I decided to trim his toenails as well and I must have gotten a little too aggressive on one of the front paws and the little guy is bleeding like a stuck pig!
Does anyone have any suggestions on how to deal with this, other that leave him outside until the bleeding stops? :confused:
   / Cut to the Quick #2
Wrap it tightly with gauze (did I spell that right?), but you'll have to stay out there with your pup for a while...until it stops bleeding.
   / Cut to the Quick
Thanks Roy, I'll give it a try.
   / Cut to the Quick #4
I guess you know there is a vein in dogs' nails...if the bleeding doesn't abate in a reasonable time, you might want to take the pup to the vet's...
   / Cut to the Quick
Well, that didn't work. The little basxxxd had it chewed off in less that 60 seconds
   / Cut to the Quick #6
Duct tape. Enough said?
Do have any vet wrap on hand? That stuff is great. We keep several rolls spread around. That stuff only sticks to itself, so there is no pulling out hair. I find it at the feed store for about a buck a roll.
   / Cut to the Quick #7
Styptic works great on gig nails....trick is getting the pup to sit still for you to hold it for 30 seconds or so. We hunt with our dogs and they have torn off nails and pads before and styptic stopped bleeding each time,
   / Cut to the Quick #8
you just need to get something up in the nail to clot the blood.. flour or bar soap (my fav) - just rub the soap against the nail like you are trying to fill it up (like a greasing a wheel bearing)...
Brian
   / Cut to the Quick #9
Septic stir same as u might use it you shave to close if that doesn't work crazy glue.
   / Cut to the Quick
Good news! The bleeding has stopped (hopefully for good). It stopped once, then when he got inside and started running around, it opened back up. Now he has calmed down and no red spots on the floor. Thanks for the advice! It is appreciated.
1991 International 4900 Box Truck (A55315)
1991 International...
2019 CATERPILLAR D6 HIGH TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2017 Toro Workman HDX Diesel Utility Cart (A59228)
2017 Toro Workman...
Sprayer Specialties XLRD 1250 Sprayer (A59814)
Sprayer...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
