DieselPower
Elite Member
- Joined
- Sep 30, 2006
- Messages
- 2,756
- Location
- Fairfield, PA
- Tractor
- JD 3020, JD 4230, JD 7410, JD 2440, MF 750, NH LS170
Yes. If I find any quantity of metal in the filter I will pull the unit out of service and start to diagnose the problem. I saved a Silver 60 Detroit in a local fire truck last year doing this. I didn't see any metal in the oil but upon inspecting the filter found a good bit of metal. Upon teardown I found a main bearing that was starting to go out. Polished up the crank, rolled in a new set of main bearing's and it went on it's way. If I had waited for 1-2 weeks to get the lab results back (which did show very high wear metal levels) it might have been to late and spun the bearing and wiped the crank.
So what did my wast of time do. It saved having to do a out of frame overhaul. They ended up only paying for a oil pan removal and rolling in a new set of bearing's.
