AMP762 said:
It was made years ago it was called a canister filter.
Well DU-UH (HE says slapping his forehead.) My 1997 1 ton Dodge/Cummins came with canister type fuel filter. It was hidden deep in the bowels of the lower part of the engine compartment and could not be seen from any vantage point I ever discovered. The Dodge garage and Cummins shops got about $75-$100 just for the labor to change the filter. I had it done at the Cummins shop so I could watch the mech do it to learn how/where.
Hr used a 1/4 inch drive with really long extension and a wobble socket and a universal and looked me in the eye while reaching into the engine with both hands and the tool. His hands knew where the canister was and how to remove the lid. All I learned in watching him was that he could do this (had to do this) without looking and that I had to make a change.
I installed a kit that remoted the fuel filter up in plain sight and used a spin-on cartridge specked for the previous year truck. There is a filter minder gauge on the assy so you can change filters based on the back pressure to fuel flow instead of months, miles, or guesses, none of which are anywhere near as good as actually knowing filter condition.
Now it takes longer to prime the spin-on cartridge (takes maybe a minute or so) than it does to change the filters. Changing filters is now one of the easiest routine maint item on the truck instead of a nightmare or $75-$100.
No, I don't cut the filter open. The last canister filter element change before changing to the spin-on showed the EVIL BLACK SLIME in the filter canister so I started in with a double dose of Biobor followed by regular standard doses and killed it out or at least controlled it with no recurrences in last few years.
IF you want to talk OLD TECHNOLOGY how about the oil bath air cleaner and the fun of washing them out and re-oiling.
Pat
