Cyclone Rake or other leaf vac
   / Cyclone Rake or other leaf vac #11
I considered a Cyclone and DR, but finally determined that I needed the maneuverability of the Kubota bagger with my BX22 /54" deck. I have a lot of trees and other landscape features. If I had more of an open field, something like the Cyclone would have been great. The problem with using the Kubota bagger for leaves is how quickly the 3 bags fill. But I found a solution of sorts. I bought a terrific Stihl backpack blower that enables me to quickly move massive amounts of leaves off the lawn (my property is surrounded by woods), then I do the final cleanup with the Kubota.
What are peoples' opinions regarding PTO vacs versus engine powered vacs?
Do you know of a pto one that has a good price point? I am willing to consider any and all options
   / Cyclone Rake or other leaf vac #13
i think i remember seeing in my owners manual for my B2400 not to run the mid and rear PTO at the same time:banghead:
The box will run both
   / Cyclone Rake or other leaf vac #15
I had a Simplicity with a pto setup that was belt operated and nothing ever went wrong with it except it didn't have enough suction. Followed that up with a TracVac with a 5hp and a 6" hose flowing into a trailer. Biggest problem with that one was the 6" hose clogged too much. Now have a 50" mower with a Commander Cyclone Rake that has an 8" / 6.5 hp set up and it really sucks. The 8" hose is a huge assist over the 6" and having an independent 6.5 hp engine really creates a lot more vacuum than anything I've had over the years. My neighbor has a 3 bagger on the back of his Gravely that I envy in the summer because it is so convenient for summertime mowing, but it doesn't compare to the Commander when the leaves start to fall. I also have a blower to blow the leaves away from the tree trunks before I start mowing so that cuts down on the banging that would otherwise happen.
I am a fan of having the largest hose you can get with an independent engine. It all comes down to the amount you want to spend - time using the equipment and money, the room you have for storage and how much maintence you will perform. Compromises have to be made on everything
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500...
2006 JOHN DEERE 650J XLT CRAWLER DOZER (A52707)
2006 JOHN DEERE...
Cushman Cart (A55853)
(4) GENERATORS (A55745)
(4) GENERATORS...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
NEW Woods 6ft Finish Mower (A57024)
NEW Woods 6ft...
