Cylinder Leak
   / Cylinder Leak #11
If you do weld.. try to wire wheel as much paint off as possible.. and if you doo see pinholes.. try to grind at them a tad.. will make for alot less spaces to fill if you are just welding up some 'v' cuts.
Soundguy
   / Cylinder Leak
</font><font color="blue" class="small">( If you do weld.. try to wire wheel as much paint off as possible.. and if you doo see pinholes.. try to grind at them a tad.. will make for alot less spaces to fill if you are just welding up some 'v' cuts.
Soundguy )</font>
good advice, thanks Soundguy
   / Cylinder Leak #13
Just to clarify, is the pin hole on the fitting or on the weld itself? (on the cylinder)
If the pinhole is on the fitting itself, and not in the weld itself, you might try to Braze it with some Silver Solder. Clean super good, flux 'till it runs into the pin hole, apply silver solder. Make sure it is sucked into the pin hole by the flux and all around it.
   / Cylinder Leak
The hole is in the weld itself, thanks though.
</font><font color="blue" class="small">( Just to clarify, is the pin hole on the fitting or on the weld itself? (on the cylinder)
If the pinhole is on the fitting itself, and not in the weld itself, you might try to Braze it with some Silver Solder. Clean super good, flux 'till it runs into the pin hole, apply silver solder. Make sure it is sucked into the pin hole by the flux and all around it. )</font>
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2005 military trailer (A53424)
2005 military...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
40' CONTAINER (A51244)
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
