Dang cracked fuel bowl
   / Dang cracked fuel bowl #21
Sure hope I didn't jinx myself reading this thread - still on original bowl here.
Okay folks, I did it. Replaced the bowl.
The new bowl still allows you to see the pleats in the filter but not the dirt or water if there is any. At least you know there is an element in there!
The new bowl seems to be tighter to install. As in, harder to compress the spring enough to get the brass colored ring to catch the threads of the filter base. I even took it apart to verify that the spring was in the proper place. The O-ring that was snug on the top of the clear bowl was also loose on the top of the milky bowl.
It all seems to work fine and is noticably softer and more flexible than the brittle clear bowl.
So, back in business.
   / Dang cracked fuel bowl #23
Mine just blew. It lasted 12 years! New one on its way.....$27!
   / Dang cracked fuel bowl #24
That's about 9 years longer than my first one lasted. Current fuel bowl is fine at 7 years.
Cannot complain. That's the only engine repair I've ever needed.
   / Dang cracked fuel bowl #25
Too bad there is not a glass one out there. The B21 bowl sure looks different in the pix I have
seen. At least the fuel filters are common: $5.
   / Dang cracked fuel bowl #26
I'm still on my original at 12 years. It's clear plastic. A few years ago when members reported the problem, I purchased a new one just in case. It's a milk color.
   / Dang cracked fuel bowl #27
Mine just has a small crack in the bottom. Leaks fuel on-and-off when operated. That's
a pricey replacement bowl, and minimum shipping from a dealer is $18. If I was not
using the tractor on pavement, I might not have discovered it for a while, maybe when
the leak got really big.
   / Dang cracked fuel bowl #28
Mine lasted 11 years. New one I just bought is milky and seems to be more pliable.
   / Dang cracked fuel bowl #29
Seems that 11 or 12 years may be about the max lifespan for these bowls. I have less than
700 hr on this 12yo tractor, so it may not have much to do with the hours on the unit.
My milky-bowl will hopefully arrive today.
   / Dang cracked fuel bowl #30
Q - If the bowl cracks and your not around for a week will it drain the tank on a CK 30 HST ?
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
(1) MAYTAG REFRIGERATOR (A51248)
(1) MAYTAG...
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
2023 JOHN DEERE 8R370 LOT IDENTIFIER 186 (A53084)
2023 JOHN DEERE...
2003 Evan's Log Trailer, Super Singles (A52384)
2003 Evan's Log...
UNUSED WOLVERINE LHR-51-23W 1R RIPPER (A51248)
UNUSED WOLVERINE...
