David Brown PTO output shaft broke! Sheesh...
   / David Brown PTO output shaft broke! Sheesh... #11
Looking at that picture, it was cracked for a long time. The break is actually just a little under 1/3 of the shaft itself and you can see, the other 2/3rds are rusty indicating a previous crack, probably a while ago.
If it wasn't cracked to begin with, the shear bolt probably would have sheared.
From the looks of her, she never sees a shed.
   / David Brown PTO output shaft broke! Sheesh... #12
Just like the axles on the IHC 300 that broke for us - you can see the rust line in the crack, where it was crystalized & cracked for a long time. The metal production/ quenching didn't take right. You didn't have much metal holding that together for some time.
--->Paul
   / David Brown PTO output shaft broke! Sheesh... #13
If you are struggling to find parts , check this guy out
www.davidbrownparts.com
maybe be able to help................ /forums/images/graemlins/smile.gif
   / David Brown PTO output shaft broke! Sheesh... #14
To the original poster. once you get it back together.. make sure you use the right grade shear pin.. not that this was the issue.. but you want to start back off on the right foot so to speak.
Soundguy
2014 Ford Explorer AWD SUV (A53424)
2014 Ford Explorer...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A52377)
2020 Caterpillar...
2018 John Deere 1653 (A55302)
2018 John Deere...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
Toro Mower (A50324)
Toro Mower (A50324)
