DC to AC power inverter to run electic tools?
   / DC to AC power inverter to run electic tools? #22
Re: DC to AC power inverter to run electric tools?
"... and SOON to have electricity..."
Well duh, Bob! Ya shoulda run the electric FIRST! /forums/images/graemlins/blush.gif Actually, I have the same "affliction" as you -- I have to customize all my tools to handle any possible contingency. I usually wind up spending more time and $ doing that versus just gettin' the work done. /forums/images/graemlins/confused.gif
I have a Ryobi set of cordless tools too and I agree -- they just don't hold up for heavy jobs. Try the Milwaukee stuff (I'm not employed by Milwaukee). You won't be disappointed. Besides, you can get great deals on eBay.
   / DC to AC power inverter to run electic tools? #23
<font color="blue"> The marine unit will be weather proof so I wouldn't mount it inside anything. </font>
A marine unit with be explosion or spark proof but will not be weatherproof. /forums/images/graemlins/tongue.gif
It must be mounted in an area where it will not get wet. /forums/images/graemlins/shocked.gif
I have a 2000-watt unit on my boat. It sure is a great item to have. /forums/images/graemlins/grin.gif
It does require a large battery bank to run for any length of time at 2000 watts. /forums/images/graemlins/wink.gif
   / DC to AC power inverter to run electic tools? #24
Does it actually have an inverter, or does it have a generator / modified dual purpose alternator setup?
Soundguy
   / DC to AC power inverter to run electic tools? #25
I am subject to correction but, it's my understanding that any electronic appratus designated as a "marine" unit will be weatherproof at least to the aspect of moisture infiltration.
Not being a boater, I dislike open water (unless it's frozen), I may be wrong.
The John Deere garden tractor is the Model 235-E and if I recall, the literature said inverter. I know it was 1000 watts, surge 1500.
OK here is the consumer reports review of the little JD garden tractor:
ohn Deere's GT models, a step up from the G100, are for homeowners with several acres or more to maintain. They are less expensive than the GX and X lines, primarily because they do not accommodate hydraulic-operated attachments. They will, however, run a tiller and a host of other attachments, including a collection system, snow thrower, rotary tiller, and more. The GT235E model offers two electrical outlets, as well. The 18-hp Briggs & Stratton engine that powers this tractor has an inverter that converts energy generated by the alternator to 120-volt AC power. Designed so you can power electric tools at locations too far from an electric source for extension cords, this feature will operate lights, power tools, and equipment requiring up to 1,000 watts continuously and to a maximum of 1,500 watts. Each outlet is GFCI (Ground Fault Circuit Interrupter) protected. For maximum output, the engine must be run at a fast speed.
Again, I figure a larger diesel tractor should be able to handle at least the same load, but at this point I'm just not sure! Anyone know what the alternator size in on the New Holland TC24D? The is the likely tractor I would install a 1500 watt inverter on.
   / DC to AC power inverter to run electic tools? #28
Once place in the manual said 35, but the back of my manual (where the rest of the specs are) it said 40AMP. I'm assuming 40 since they probably uped the spec, but didn't update the entire manual.
   / DC to AC power inverter to run electic tools? #29
5030
When I'm using my bush hog, the screen in front of the radiator gets clogged with fuzz and "stuff" from the "stuff" I'm cutting to the point where the engines starts to run a little warmer than normal.
Placing the inverter in front of the radiator would surely subject it to all kinds of "stuff" and dust. It would probably need to be blown or brushed off before using it to keep it from overheating. Other than in front of the radiator, which is good because it's next to the battery, there isn't much room under the hood on my Deere CUT.
   / DC to AC power inverter to run electic tools? #30
5030
I checked the site for one of the most common used inverters on boats.
The units are not even explosion proof as I thought. /forums/images/graemlins/tongue.gif
Here is a link to the site. Click Here
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
1999 Kubota L2500D Utility Loader Tractor (A55851)
1999 Kubota L2500D...
Cushman Electric Utility Cart (A55851)
Cushman Electric...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
Portable Bathroom (A55853)
Portable Bathroom...
2013 Freightliner M2 106 Stellar 12621 6-Ton Mechanics Crane Truck (A55852)
2013 Freightliner...
