MarkV
Super Member
- Joined
- Apr 7, 2000
- Messages
- 5,698
- Location
- Cedartown, Ga and N. Ga mountains
- Tractor
- 1998 Kubota B21, 2005 Kubota L39
Shvl73
You are right on all counts. Water base poly is much thinner than oil base and requires about 3 times the number of coats to get any good build up. We use oil base because we feel it has been more durable, in our experience, on floors. I do use water base poly on some non-floor projects and particularly like it on cedar. Cedar tends to darken with age and if an oil base finish is used it darkens much more and faster. We have a vacation home that is mostly cedar inside and I sprayed 2 coats of water base poly on most everything with good results. Water base poly is also very clear when it dries where oil base has a bit of an amber tint to it. Another advantage to the water base poly is that it dries very fast and can be recoated in about an hour.
MarkV
MarkV
