GreatWhitehunter
I posted this over in the deere forum but got no replies. I have a deere 3320 hydro and had a small issue while harley raking a customers lot. I was raking and lifted on the rockshaft control lever(3pt control handle) and no lifting occured. I got off the tractor and fiddle around with a few things. Such as the raise and lower speed control valve. Still no lift so I figured it was either low oil or a plugged filter. So I pulled off the power beyond inline filter(sintered) And low and beholf the center of the filter is missing ( about the size of a pea) So I hauled it home into my shop for the disection. It seemed that none of the other hydralics were affected other than the rockshaft. I took ever piece of the rockshaft system apart ( I talked to my dealer for support) and found no issues. I took the entire rock shaft pilot control valve apart and still found nothing. While I had the valve off I put air into the system and found nothing. No restrictions nothing. I then took the piston itself apart thinking there was something stuck in there. Nothing was found. So I put everything back together and was going to bring it to the dealer. Which I really didn't want to do for money reasons. So I try the rockshaft after it's back together and it works no issues. So now I'm confused and had expected to find the missing piece somewhere in the system. So I started using the tractor at my place and all seemed normal. But today I hitched up to my bushog and had to increase the rpms to get it to raise to full height. So I was using it today to do some loader work and was working on an incline. I had the rpms about 18k (which normally would would be more than enough for this task) I needed to bump the rpms up to 20k to keep a steady pace? So now I don't know what to try. I believe there's separate pumps for the hydrostatic drive and rockshaft but I believe the sump and filters,lines are common. I really need to get a game plan together and fix this thing
100%. Unfortunatly I lost my real day job last week(another story) so I really want to avoid taking this to the dealer a 100 an hour and feel capible of making the reapirs myself but I'm not sure what direction to head? I was thinking I should get a gauge and test the system pressure. Then if that's sat I've got the think it's a plugged line somewhere? So I'm looking for some suggestions and comments. Sorry for the long winded post.
Matt T.
Matt T.
