Deere X485 Transmission
   / Deere X485 Transmission
They would switch over cab, heater, loader and I'll need a different front PTO.
The cost of new is $4100 another $500 misc parts and labor of around $1200.
There is no chance of rebuild.
Dealer has a X728 in stock going to try and make a deal, I really have little choice as far as I can see.
Thank you to all for your great responses.
   / Deere X485 Transmission #12
You always have a choice...
Sounds like the work you have for the tractor might be too much! If that's the case, moving up a couple of tractor sizes in the same series might only be setting the stage for another failure in another couple of years..
Have you considered the new 1000 series tractors?
If you part out your current machine and sell off the various components does the "math" look better?
AKfish
   / Deere X485 Transmission #13
occasionally I see jd transaxles in the "surplus center" listings. (one advertiser on TBN) don't know if any are the correct one.
   / Deere X485 Transmission #14
There are always people parting out tractors on eBay. I would look around for a while before buying, the grass is not growing...... Yet.
There are 3 transmissions for the X series. The one listed on Ebay is for 4 wheel drive.
The X485 is worth about $3500 - $4000 on trade without mower deck in good running condition.
   / Deere X485 Transmission #17
I think if you have the dealer make the repairs you might as well cough up $10k+ and get a new one. If you can and would consider repairing your existing mower yourself you could do it for alot less, around $3000+, depending on the cost of the transaxle. Haven't looked at or researched whether the transaxle on EBay would work for you but that is the premium 2ws axle and is indicative of what you can find if you look. The actual 2wd transaxle you would wan't should be less.
But if you wan't new with no hassles go for it.
No hassle plus I need to put the tractor back to work. We had a lot of heavy rain the past couple of days and could use loader & sweeper.
I bought tractor new in 2002 from the same Deere dealer that has been around since 1951, they are doing there best to work with me. It does pay to be a loyal customer.
   / Deere X485 Transmission #19
If you need it now, You would likely have to trade. Up Time for needed equipment would be a deciding factor. Let us know how it turned out.
Here is my X485, what's left of it!
INSPECTION (A54865)
INSPECTION (A54865)
TAKEUCHI TL12R2 SKID STEER (A52705)
TAKEUCHI TL12R2...
UNUSED LANDHONOR LHR-CIA200 - 200# CAST IRON ANVIL (A54757)
UNUSED LANDHONOR...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55788)
2015 Chevrolet...
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A52706)
2016 CATERPILLAR...
2007 Sterling Acterra Dump Truck (A51691)
2007 Sterling...
