Demountable trailer wheel/tire
   / Demountable trailer wheel/tire #11
We're not talking tires or axles, we are talking about using a steel wheel from a MH dealer as a spare with one of the used non MH tires the OP has. Do you have a reason why the steel wheel would go bad?
My apologies Dr. CrazyAl! You are right, the wheels would be fine. I guess I got a little lost cause to tell you the truth, I'm not sure I know what's being discussed here:
I have a factory built equipment trailer with dexter 6000lb axles on it. It has the mobile home type wheels on it, but the are real deal, not from a mobile home. The brake flanges are bolted on. I am replacing the two older tires with new 8-14.5 tires meant for equipment trailers, but I want a spare. I am going to keep one of the old tires and find a rim for it. Is there a difference in the rim width from the 7-14.5 vs the 8-14.5? Can I just get a rim from a MH axle and put proper tires on it?
   / Demountable trailer wheel/tire #12
No problem. I just assumed the wheels were the same, if not I would like to know. I have a 11 ton 3 axle equipment trailer with these axles under them and the last thing I need is to find out that I may have sub par wheels that I'll want to replace.
I yanked one of the trailer tire/wheels off the trailer tonight. My dad had a couple of MH wheels laying around from an old homemade trailer. One of the old MH wheels still had a 7-14.5 tire on it, one had no tire. They are the same size wheels as the ones on my trailer. I could not tell any difference in the thickness of the metal. If anything, the finish might be in better shape than the ones on my trailer.
I considered swapping to 6-bolt drums & 15" tires, but I figured I would have $800.00 invested by the time I do all 4 wheels and I still would want a spare. Maybe in a couple of years..
Kubota LA853 Loader Arm (A51691)
Kubota LA853...
1995 VOLVO BM A25C 6X6 OFF ROAD WATER TRUCK (A51246)
1995 VOLVO BM A25C...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
Skid steer auger plate (A50322)
Skid steer auger...
toro turf sweeper (A50324)
toro turf sweeper...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
