Depending on Demand, We may be going Vertical.
   / Depending on Demand, We may be going Vertical. #21
Should work fine if you can run the discs straight and be sure to keep the axles a little longer for the thicker 6mm coulter blades. Ken Sweet
No problem. Now I need 28 coulters--maybe an early birthday present for myself :).
Great Plains is now making one with the disks at a slight angle. It does not work like a usual disk, but it is better at killing weeds. My dad has a 25' (i think) straight blade model an it does not do as well as he had hoped for killing weeds especaily mares tail.
Corn tilled only with it did do quite well though.
We make ours gangs adjustable, just in case, the customer has a need to run at a angle. Ken Sweet
2019 Deere 550K (A53317)
2019 Deere 550K...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
Case Axial-Flow Combine Wheels NO RESERVE (A56436)
Case Axial-Flow...
