Determining maximum cutting torch tip size based on acetylene bottle size?
   / Determining maximum cutting torch tip size based on acetylene bottle size? #11
I guess my question, is will you be using the torch for more than a few minutes at a time. If you will be heating with a rosebud for hours on end, then buy a 330 CF tank. I, like others here, use a 0 and 00 most of the time for up to 1" thick. It takes longer to get it hot enough to cut, but once hot a 0 tip will cut 1" plate easily. I have a small (75 CF ) acetylene tank and I can run a small rosebud for heating with it, but I never need more than 5 minutes to heat anything around my shop and an 0 tip will cut anything I need.
Thanks everyone! Being a 'wannabe' welder, my requirements are toward the lower end, and it sounds like the tips will cut thicker material than stated with patience. I'll buy the #4 rosebud use it only for short periods of time. Thanks, Toukow!
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
Golf Cart (A55787)
Golf Cart (A55787)
2023 yamaha (A55758)
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
2026 Anvil Trailer (A56859)
2026 Anvil Trailer...
