Detroit diesel problem
   / Detroit diesel problem #31
Hello, this sounds like the trouble I had with my mf 135. The cause was a small filter in the fuel tank was partly blocked. You couldn't see it through the fuel cap hole.
The solution was as Plumbstraight says with the compressed air, blow back into the tank and this clears the blockage to get mobile .( NB take the fuel cap off first). A permanant fix in my case required cleaning the fuel tank. Good Luck.
well, I got the line from the tank to the first filter primed and sure enough she started right up. thanks guys!
   / Detroit diesel problem #33
Glad to hear it Chris. How'd you get it primed?
Put a check valve on that line between the tank and first filter (or a shutoff valve) and you'll never have trouble again.
   / Detroit diesel problem #34
Sorry I didn't see this sooner. The original problem definitely sounds like fuel starvation. Is it still acting up now that you've changed filters and got it re-primed? For what it's worth none of my Detroits have ever gelled.
2022 ISUZU NQR 18FT FLATBED (A51222)
2022 ISUZU NQR...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2020 KIA Sportage (A50324)
2020 KIA Sportage...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A49461)
1990 Ingersoll...
