Did these come to North America too?
   / Did these come to North America too? #11
Are theyre any attachments for these like you'd find on a BCS? Or is the tiller section permanently attached? They look pretty able.
I Googled on walking tractor Asia and saw a lot of info. These 'walking tractors' are widely used in some regions.
Example:
Walking tractor field tests in Uganda.
Testing and evaluation of the performance of the Siam Kubota walking tractors was carried out in sample districts like Soroti for Eastern region, Mukono for Central Bushenyi for South and Kitgum for the North. Results of the testing and evaluation indicated that the tractor could successfully open up land in light soils.
It was also observed that the tractor could transport farm produce and goods of up to 1,000 kilogrammes on a simple trailer, which can be fabricated locally.
The current walking tractor models use diesel and are of power range 8 HP to 4HP. The 12 HP Kubota walking tractor can do all operation in the value chain and primary processing.
Each of the walking tractor units was supplied with standard implements, which include disc plough, mould board plough and a harrow (rake).
They were also supplied with implements like the planter, disc and mould board ridger.
Technical performance:
Ploughing: A power tiller can plough 1.6 acres in a day with eight litres of diesel worth about sh50,000 including labour.
Harrowing: Seed bed preparation is done on previously ploughed garden to attain finer seed bed free of unwanted materials in readiness for planting. This operation is achieved using a harrower. One acre needs two to three litres of diesel in and the work done in less than two hours.
Weeding: Weeding needs the use of a weeder to remove unwanted plants in short period. Water pumping: A water pump is attached to the engine using support bracket with power transmitted through attached belts to utilise pumped water. On the farm, the water is used for irrigation, watering livestock and domestic purposes.
Transport: They can transport agricultural produce and people up to a capacity of 1,000kgs.
Agro-processing: The power tiller engine can run various primary processing equipment such as maize shellers, saw mills, grinding mills, rice shellers, and forage choppers.
   / Did these come to North America too? #12
California: Thanks for the link. Those things are BIG! The pictures didnt do it justice, check this video for a sense of scale http://video.google.ca/videoplay?docid=839027967571414209&ei=VmvrSfv7J4P--gHkrcGNBg&q=walking+tractor+&hl=en&client=firefox-a
I couldnt find one with a traditional PTO, only belt drive. One of those running a flail would be pretty awesome as a brush cutter. I looked, but didnt come across one.Also, if im correct, that yanmar is only a 8Hp? It sure looks a lot bigger than that to me.
   / Did these come to North America too? #13
I have a Yanmar diesel tiller just like the one in the picture.
Its a monster that will eat you alive if you fall under it (no joke)
It starts with a handcrank & a compression release.
It has 6 fw gears & 2 reverse gears ,self propelled, squeeze the handle on the right and it turns on a dime. Easy on fuel too.
It will till thru almost anything,
not sure, but it would make a monster snow brush
thanks for posting that video, Pulling the trailer with it and 3 guys riding :D:eek: is awsome
   / Did these come to North America too? #16
I wonder what these would look like if they were sold new in the USA? I bet it would have so many safety levers, shields, warning signs, stickers, switches, buzzers, flashing lights, roll bars, sirens, & guards on it that you would not recognize it. The Japanese get all of the cool stuff. We aren't even able to buy lawn darts anymore because they are too dangerous. :)
Aaron
Parts@HoyeTractor.com
(940)592-0181
   / Did these come to North America too? #17
Aaron
(940)592-0181
Aaron,
You are soooo right about dangerous.
You do not want to have a drink or loose control of this machine at any time, cause your life is at stake!
Osha would have a fit if they saw it :eek:
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
2021 DEERE 333G LOT NUMBER 198 (A53084)
2021 DEERE 333G...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
