Diesel and kerosene 50/50 mix?
   / Diesel and kerosene 50/50 mix? #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
I went to fill my 50 gal barrel with off-road diesel and the pump had a new sign on it that read "this product contains 50% kerosene."
I know that people often mix some kero in diesel for the winter as an anti-gel but 50% seems like a lot! (I usually put in an anti-gel additive myself.)
Seems like a lot of the lubricant would be diluted out.
Do y'all think this is safe to use on my modern common rail, high-compression Kubota diesel?
Thanks.
   / Diesel and kerosene 50/50 mix? #2
Yes it is safe to use. Around here they just call it winter blend. You may notice a slight loss in power but it won't hurt your engine
   / Diesel and kerosene 50/50 mix? #4
Yep, winter blended fuel so as not to gell up on you in the cold, half #2 and half #1, you could add a standard dose of power serve and be ready for anything mother nature sends your way.
Fuel usage will be slightly higher and power slightly less but not really noticeable.
   / Diesel and kerosene 50/50 mix? #5
50/50 is NOT a lot of kero in the diesel, to keep it from gelling...
SR
Thanks for the reassurance y'all. :thumbsup:. I guess I'll still add my anti-gel additive too based on the last to comments. Thanks!
   / Diesel and kerosene 50/50 mix? #8
Just an opinion I feel in never hurts to use a fuel additive with lubricity.
   / Diesel and kerosene 50/50 mix? #9
I have noticed fuel usage is up, but it sure beats gelled up filters !
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
2006 APPA TL (A55788)
TREE PLANTER (A52708)
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
