I have an update for (some?) members: :stirthepot:
Diesel Fuel Lubricity:
In Minnesota, current state law requires all retail diesel fuel pumps to dispense at least 10% "biodiesel" blend diesel fuel. I believe I read this law's definition of biodiesel is per the recent ASTM specification in order to control quality. The famous Spicer report of 2007 clearly documents that biodiesel, even in low concentrations, was the best lubricity additive tested, and surpasses diesel fuel injection pump manufacturer's wear requirements. Footnote: MN is trying to increase biodiesel blend concentration to 20%, but is running into resistance from truckers over storage stability & winter pumpability concerns.
Pros: In MN, supplemental diesel fuel lubricity additives
should not be needed.
Cons: (1) Enforcement of biodiesel is suspect (to me), as it is only a state, not federal, law. There is no associated quality labelling on the dispensing pumps like there is for federal USLD low sulfur limits, or for octane levels on gasoline pumps (also min. ethanol content in gasoline).
(2) Biodiesel degrades much faster than refined diesel, leading to more questions about quality & freshness at the retail pumps, as well as for storage by the consumer. Are biocides added? Who knows?
(3) Biodiesel congeals at higher temps. than refined diesel. This is a big deal for us in the northern U.S. For sure we need antigelling additive during the winter (use tractor for snowblowing).
Conclusion: Once again, we are back to not being able to tell for sure what is coming out of diesel fuel retail pumps in terms of labeling & enforcement. If the fuel truly does have 10% biodiesel in MN, no lubricity supplemental additive is necessary. But if it does not, the Spicer report clearly shows an additive is necessary. Since biodiesel is both a combustable fuel as well as a lubricity additive, there is no harm in adding supplemental lubricity additive to it. Therefore, we must still err on the safe side & add supplemental lubricity additive until such time as regulatory agencies label AND ENFORCE diesel fuel lubricity at the retail outlets.
Diesel Fuel Cetane:There is no state or federal mandate I am aware of for minimum cetane number in diesel fuel. Some surveys have shown most retail outlets in the U.S. have diesel fuel cetane numbers around 40, which is way too low for my engine (51 min. recommended). Biodiesel is supposed to improve (increase) cetane number. But again, nobody knows how much - there is no retail pump labeling or enforcement. We have "Premium" diesel fuel available in MN, but even this fuel has insufficient cetane number for my engine:
link-->
Performance Fuels with extra power, reduced emissions, better mileage, faster cold weather starts and performance, environmental friendliness and other benefits which exceed industry premium diesel specifications.
Footnote: Premium diesel fuel is available at all Mills Fleet Farm fuel stations, some Kwik Trip stations, some Cenex stations, some Freedomvalu (Erickson) stations. MN only has 3 fuel wholesalers due to major oil company pullout of this remote market some decades ago. The Premium fuel is supplied by Flint Hills Resources refinery in Rosemount, MN (formerly known as Koch Bros., still owned by them - they changed the name to hide their reputation).
Conclusion: Supplemental diesel fuel cetane booster additive is always needed for my engine. Higher cetane also helps keep fuel system parts cleaner due to more complete combustion, but many diesel fuel cetane boosters also contain detergents to ensure fuel system cleanliness & longevity.
BOTTTOM LINE
In MN, we continue to be stuck with unknown diesel fuel content, as with most locations in the U.S. Various state government attempts to legislate content (mostly due to farm lobbyists) are questionable, at best. Until there are SUFFICIENT diesel fuel quality requirements enforced across the U.S., use a quality additive to ensure proper diesel engine performance & longevity. The fuel system is too expensive to risk to chance.
What do members think? :confused3:
