Oil & Fuel Diesel fuel?
   / Diesel fuel? #11
Just a tip for anyone that buys fuel in bulk for their tanks. Buy the unblended fuel and put in the right amount of power service. You will save average of 10 cents per gallon. It's also safer because you know your fuel has been treated and won't gel.
   / Diesel fuel?
Thanks Bob! You've been a big help!
   / Diesel fuel? #13
</font><font color="blue" class="small">( Someone I know said they monitor fuel as 2 tanks of #2 and 1 tank of #1? Anyone know the reason?
What should I be using for my new 4320? And why?
Thanks
Merry Christmas
4320w/400x,hd bucket, LX6, RB1184 w/hydr. /forums/images/graemlins/confused.gif )</font>
#1 is Kerosene
#2 is Fuel Oil/Diesel Fuel
Kerosene is cleaner and less oily than diesel, thus the #1 rating.
The only difference in Fuel Oil and Diesel Fuel in most areas of the country is the additives, to keep the fuel from gelling, and dye to indicate level of taxation.
Some of the level of junk you find in the fuels is more dependent upon the delivery system than the type of fuel. Dirty tanks and tanker trucks is gonna get you dirty fuel.
We get our diesel at a distributor, which is referred to as a bulk plant. Because it is for off road use we do not pay the highway taxes, making it 40-45 cents cheaper than at the filling station pumps.
I gotta agree with Richard, you are better off depending on yourself for additives, and not the diesel suppliers. In the late fall they will go ahead and give you warm weather fuel that is left and your fuel could gel. In late winter/early spring they may stop producing the cold weather fuel too early, and it could also gel.
Fuel stabilizers are good for gas and diesel that is apt to sit for a while.
   / Diesel fuel? #14
</font><font color="blue" class="small">( The only difference in Fuel Oil and Diesel Fuel in most areas of the country is the additives, to keep the fuel from gelling, and dye to indicate level of taxation. )</font>
This may be a dumb question, but why wouldn't fuel oil need anti-gel protection too? Wouldn't an oil furnace shut down if the oil gelled in the supply line?
Tom
   / Diesel fuel? #15
[quote
This may be a dumb question, but why wouldn't fuel oil need anti-gel protection too? Wouldn't an oil furnace shut down if the oil gelled in the supply line? )</font>
Just guessing, but I imagine it's because heating oil is usually not stored outside above ground.
Cliff
   / Diesel fuel? #16
The fuel in vehicles gels because it is brought down to a finite amount for the injectors. The fuel doesn't gel in the tanks, the fuel gels in the fuel supply system. A heating system has 20-100 times larger fuel nozzles than a typical injector system.
   / Diesel fuel? #17
</font><font color="blue" class="small">( The fuel in vehicles gels because it is brought down to a finite amount for the injectors. The fuel doesn't gel in the tanks, the fuel gels in the fuel supply system. A heating system has 20-100 times larger fuel nozzles than a typical injector system. )</font>
Thanks for your answer, cowboydoc. Let's see if I have this right. If I understand you, the gelling would happen in the high pressure fuel lines leading to the injectors, not in the line supplying the fuel pump? Interesting. /forums/images/graemlins/smile.gif
Cliff,
Thanks to you too. I thought about the furnace oil being stored underground, but I wasn't sure everyone did that. I can remember when I was a kid our oil tank sat right outside the kitchen. Of course that was a few decades ago.
Tom
   / Diesel fuel? #18
Depending on the size of the lines to the pump it's possible but usually it has to be very, very cold for the fuel to gel in the supply lines.
   / Diesel fuel? #19
Straight Diesel will gel if cold enough, have seen it gelled in filters also. I would assume all northern areas cut the diesel with kero for winter anyway.. at least around here they do.
As far as fuel oil for home heating, outside tanks, for mobile homes etc,, use straight kerosene instead of fuel oil.
We recommend Stanadyne fuel conditioner for all diesel applications, and actually recommend it for year-round usage. I know there are other similar products also, and other threads pertaining to additives.
Where's the snow????
/forums/images/graemlins/cool.gif
   / Diesel fuel? #20
<font color="blue"> Just guessing, but I imagine it's because heating oil is usually not stored outside above ground. </font>
Our home, built around 1900, had an outside oil tank from the time the furnace was first installed and for the first 20 years we owned the home. When we needed to replace the furnace, we had the tank moved into the basement. There was about one foot of line from the bottom of the tank before it entered the foundation. In 20 years, we only had the line 'freeze' once.
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
Informational Lot - Financing (A53472)
Informational Lot...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A53472)
Hay Van FL-95 Bale...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A53472)
FIRESTONE 9.5L-15...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
