JimRB
Have you ever gone 4 wheeling with the Hummer club? H1s that is. You go off roading with them, someone will teach you have to drive off road using your ABS and no traction control. The later consumer retail models had traction control. With the H1 and no traction control, when you had wheels spinning you apply the brakes and the throttle. The ABS helps slow down the spinning wheels so the wheels with traction can work. Of course the H1 came with an automatic which makes that task easier.
My 2wd long bed Cummins weighs 6,000 pounds empty with probably 4,000 pounds on the front wheels. I get stuck fairly easy as most of the weight is on the front wheels. If you refuse to weigh the back end then you are on your own. It costs you a lot less to toss 500 pounds in the back end for the winter than it does to be smashing in to things or going no where because you are spinning.
