Diesel Storage and Grades
   / Diesel Storage and Grades
John,
For me it probably wouldn't be worth the 55 gallon size. Don't use my tractor enough but I figured I would at least go with a 15 or 30 gallon storage. That is probably good for me just the thought of dragging 5 gallon cans around...what a pain /w3tcompact/icons/eyes.gif. I plan on putting up a quick shelter to store my diesel in away from the shed. Any comments on storing diesel and gasoline in the same area. Too many fuel cans around the shed, I figured it would be safer to move the fuel away from the tractor...Tractors come first /w3tcompact/icons/grin.gif.
   / Diesel Storage and Grades #12
<blockquote><font size=1>In reply to:</font><hr>
<hr></blockquote>
I went through maybe 8 gallons of diesel last yr on my tractor. I bought a 6 gallon gas can to buy my diesel and like you regretted it. My fuel tank only holds 5 gallons and it is never empty so I found myself holding 50 pounds of fuel over the tank trying to pour less than half of it into the tractor. I suppose I could do what harv does and string it up with some rope. Instead, I am looking to see if I can find a 2.5 gallon yellow diesel can. 2.5 gallons is like 2 months worth, is half a tank on the b7200 and weighs half as much as a 5 gallon can. That way I fill it up when it is half empty, always empty the can into the tank and always have fresh fuel.
While I like the though of having a fuel reserve, it is very hard to justify a barrel with lots of fuel with just a single compact tractor.
   / Diesel Storage and Grades #13
I use a $3 plastic kerosene hand pump/syphon. Just set the 5 gal. plastic can on the hood, one end of pump in the can, the other in the tank. A couple of squeezes on the bulb of the pump and gravity takes over. No mess, no fuss.
   / Diesel Storage and Grades #14
Norm-Great idea about the pump. Where did you buy it?
   / Diesel Storage and Grades #15
Ace Hardware in Trenton, Ga. carries them. I imagine any place that sells blue kerosene cans will have them. I have even bought cans that come with a pump.
   / Diesel Storage and Grades #16
I've seen similar fuel cans/pumps at Menard's. If Menard's handles things like this, I'd bet that Home Depot and Lowe's would too.
   / Diesel Storage and Grades #17
Home Depot sells an $11 battery operated pump and that is what I use. It takes 2 D cell batteries. The thing works really great, empties a 5 gallon fuel can in about 2 minutes. You stick one end in the can of diesel fuel, the hose end in the fuel tank, and turn it on. Works great.
   / Diesel Storage and Grades #19
2008 KALMER 4X2 SPOTTER TRUCK (A54756)
2008 KALMER 4X2...
Miles read : 112,969 (A50323)
Miles read ...
2013 Nissan Sentra Sedan (A53424)
2013 Nissan Sentra...
CATERPILLAR CB24B SMOOTH DBL DRUM ROLhttps (A52705)
CATERPILLAR CB24B...
2014 Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
2014 Peterbilt...
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
