"Want power? Pull that powerstroke out and put a Cummins in... Ya, the Cummins/Dodge would be good, but I'm talking a big step forward. Do something like the Cummins 8.9L 350hp 1500ft/lb "
Of course Robert, thats if your just pulling the little stuff. If you really need to pull a load and want to meet the latest in diesel emissions, the new GE Evolution 12 cylinder diesel is available. While its only got 4400 HP, the torque is more then enough to snap every u-joint, axle, drive line, ring & pinion commonly available. Typical use is in locomotives so size may be a factor. If thats not enough, the new GE jet engine (GE90 115 B) should be considered. Thrust is double that of the current 747 engines. In either case, a 6 speed manual will perhaps be the wiser choice for durability. Rat
