Diesel vs gas
   / Diesel vs gas #141
Yes they will, but I'd hate to try and stop that load on a hill with that old girl :cool:
That being said, we still use several gas tractors for farm work, Farmall 400, 560 and 656's for light work.
All the newer units are diesel.
This discussion (piss ant argument ) about gas vs diesel has had so much bull slung around it's ridiculous.
Diesel has more BTU per gallon, other aspects of engines being equal it will take less fuel then gas.
I've heard so many ridiculous claims in the discussion,
the cam(s) or valve timing (electronic) is what affects the engines power curve, it does not matter if it's gas or diesel.
With forced induction and new electronic controls both engines can make unbelievable hp and torque.
As an example a little 3.0 liter (183 cu.in.) diesel with 240 hp and 420 #'s of torque at 2000 rpm.
For lighter work I would like to see a modern 50-60 hp @ 2000 rpm gas tractor with a good flat torque curve and a base weight of 5000-6000 lbs,
and a diesel with the same Hp and torque and weight, it would be an interesting (at least to me) comparison.
And for those that want or claim that higher rpm is as good or better then low, no.
Good stuff Lou.
Isn't Ford's little gasser V8 they use in the F150 a 2
7L that build incredible numbers?
For how long we'll see. :)
   / Diesel vs gas #144
OK I now better understand your objective in your OP.
Gas options are typically older stuff like you mentioned.
Our 1976 MF 265 diesel was bought new by the wife's father and is a nice low hour (1400) 60 HP tractor.
I grew up on gas 801 Fords so late last summer I looked at some 3000 Fords. I was fine with gas. I looked at one gas and one diesel both would start and run but nothing to get excited about taking home. The next week a 1966 3000 Ford diesel popped up nearby on CL that ran and looked very nice and apples to apples was the better value so we got it and now it has the 711 Ford one arm loader on it. Very early this spring I looked at a 3600 diesel and a couple weeks later a 2600 gas tractor that I pulled a trailer 300 miles to buy. The guy finally got it started but the old carb issues came flooding back into my old head from years ago plus it looked much better in the photos. The 3600 diesel was just 15 miles away from this 2600 and I had the trailer so I drove over to the place with the 3600 diesel because it would start and run very nicely plus it had a strong lift that could hold up a 5 foot bush hog for a few hours after you shut it off. The guy still had it so he loaded it and I headed back to KY. I notice Friday the 3600 is at 2400 actual hours (I was told and appears to be factual) so I have put 100 hours on it this summer somehow I guess pulling the 7' twin spindle Bush Hog brand bush hog. In heavy stuff it will show some dark smoke when the governor opens up but has not used any oil. The owner of the last 32 years knew the owner who bought it new and he claims the engine has not been touched other than to change the oil and filter every 100 hours and mainly it cut and raked hay he said.
I was very open to an old gas Ford but in the real world of old tractors my brain had to go with diesels for the reasons noted. I have not seen any new gas tractors in years.
In a practical sense there are mainly only diesel tractor options today. I am sure a 3000 Ford gas or diesel will do about the same amount of work but the life of a gas engine just does not compare with the diesel version 50 years down the road from what I can tell. :)
While the 3600 has set outside all of its life and needs painting and some other stuff to make it look sharp it is turning out to be a real work horse as is and the price was $3500 picked up at its home of 32 years.
If I had a family gas tractor I would restore it I am sure.
Why would manufactures build gas tractors when diesel was here and still is 2/3 to 3/4 of the price of gasoline per gallon outside of the west . Same reason why some diesels are currently being used in some applications better suited to gasoline. In most of the world diesel is much cheaper than gasoline.
   / Diesel vs gas #147
The funny thing is both are going to be replaced by battery powered tractors like the cars and semi trucks.
   / Diesel vs gas #148
   / Diesel vs gas #149
I say we go back to kerosene, it was the cheapest thing ever back in the day and less polluting..........I still have a tractor that will burn it - shoot its all our ancestors had and used for tractors/heating/lighting/cooking etc.............where did that go wrong?
1982 LeeBoy Motor Grader (A53472)
1982 LeeBoy Motor...
2016 R&R Products 331 LP Reel Mower (A51694)
2016 R&R Products...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A53472)
NEW 2025 Load...
2014 BOMAG BW 213 DH-4 (A52472)
2014 BOMAG BW 213...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
