bx23barry
Platinum Member
- Joined
- Jun 17, 2006
- Messages
- 500
- Tractor
- Kubota BX23
<The Power Bar (made from apple cores and waste newspaper) I ate at the bottom would be what propels me to the top of Mt. Whitney, not oxygen.>
O2 is what turns that power bar into useable energy.
<Where is it stated that that is the case with a diesel engine?>
Doesn’t matter. It is true with all internal combustion engines, but I was indeed referring to diesel engines.
<The amount of fuel injected is chosen by many factors engine durability being probably the foremost one.>
Yes but I am talking about maximum power.
<MUCH more power can be extracted from a diesel engine by simply adding more fuel. To illustrate this point, look at the immense columns of black smoke coming from a pulling tractor by simply injecting more fuel, you can see that for a normal diesel engine, the maximum amount of fuel is not being injected. In some cases, they even inject additional fuel (propane) into the intake air. How is it that this propane burns if all the available oxygen is already consumed? More fuel could not be added if there wasn't sufficient oxygen for it to burn.>
My point exactly, to produce maximum power all the available o2 must be ignited.
<As I have illustrated above, normal diesels do not fuel enough to produce maximum power at sea level because we want them to last a while.>
Ok so you are not talking about maximum power. A "lean" "normal" diesel may indeed not lose so much as a gas engine at slightly lower elevations but would lose power at all altitude because of lower effective compression ratio caused by the less air density. At some point it wouldn’t even run because there wouldn’t be enough heat generated from compression to ignite the fuel (why non-aspirated diesels don’t fly so well). "Lean" "normal" diesels do in fact lose power at altitude if you want to prove it just find some real mountains to take your diesel over.
