Diffy housing change by self
   / Diffy housing change by self
I finished it and then put it back together. Everything worked when I put it back together. Then I was using it and the new housing cracked. So I raised up the brush hog and put a bar under the hyd arms and made the 50 into the most expensive lawn mower in town. The only thing that I can do with the tractor is mow. But at least I can cut things down (weeds).
I was able to seal the cracks with a filler and I can get the hydrolic arms to rise and fall normally. So what I do is raise the arms to get the implement on then I lower it down onto a steel bar to take the weight. I feel that I can do this until it cracks more. By then it will be time to get a new tractor.
UNUSED CFG INDUSTRIAL MH12R EXCAVATOR (A58375)
UNUSED CFG...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
40 (A52708)
40 (A52708)
2021 Kubota SVL 97-2 High Flow Skid Steer (A59213)
2021 Kubota SVL...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
