Digging a farm pond - need advice.
   / Digging a farm pond - need advice. #1
CajunRider
Platinum Member
Cajun Land
Kioti DK45
I am planning to dig a farm pond 250ftx150ftx10ft deep. Any suggestion on method of construction such as proper bank slope for erosion protection and breeding is appreciated.
I also plan to stock the pond. What do you suggest? I live in Louisiana. The pond will be dug in an area that used to be a rice field.
   / Digging a farm pond - need advice. #2
Rent a dozer and a man to operate it who knows what needs to be done. Seriously. Trying to dig a pond with a CUT is a very very long project. Depening on your soil, you may need to bring in clay for the bottom and/or you may need to add a synthetic liner.
   / Digging a farm pond - need advice. #3
Your planned pond is very similar to the same size as one of mine. I dug it with my backhoe over several months. The digging was the easy part, removing the dirt was what realy took the most time.
I only went 4 feet deep except for a drain hole that is about 7 feet deep. I did that to allow me a place to pump from if I wanted to drain it for some unknown reason in the future.
On pondboss.com they talk allot about pond construction, stocking and design. It's similar to this sight.
They all recomend only going 4 feet deep since fish only use the top four feet of water in the pond anyway. The other problem with deeper ponds is twice a year the water will turn over. The cold water at the bottom will rise to the top and force the warm water down. I forget why this happens.
When it does happen, you can expect a massive die off of your fish because they will remain at the same top 4 feet of water, which is now much, much colder then what they need to survive.
The mixture of fish you use is really important to your area and what your goals are. I don't know a thing about fish, so I wont comment on it.
   / Digging a farm pond - need advice. #4
EddieWalker,
I'm going to have to respectfully disagree with your recommendation to dig no more than 4' deep for a pond. While it may work in certain cases such as ponds with a constant level and little influx of sediment, it's a recipe for disaster in Texas. It's not uncommon for evaporation alone to lower a pond by 3-4' during the summer here. Unless your pond is supplemented with a well and sediment influx is very minimal, you are going to have problems very quickly.
Sorry to be the bearer of bad news. I don't know who you were listening to over on Pondboss but they gave you some bad advice it sounds like. If you let me know some more details either here or in a PM, I'd be happy to give you some additional advice.
   / Digging a farm pond - need advice. #5
That didnt sound right to me either. Might be able to raise carp and shoot ducks though.
   / Digging a farm pond - need advice. #6
CajunRider,
I suggest you visit the link provided by EddieWalker and myself for more information specific to your location. I can give you some general advice.
You will need a dozer for a pond that size. From what you describe, it sounds like you will be digging a hole and not constructing a dam. Make sure you have a source to fill the pond, whether it's groundwater, surface flow, or a well. If you plan on doing it yourself, I would still get some advice from a knowledgeable person on site, even if you have to pay a little for it.
You want probably a 3 to 1 slope, but that would depend on your soil type. One thing you want to avoid, unless you want submerged vegetation for duck food, is shallow water. I would recommend reaching 3' deep water as close to the shore as possible.
Don't make a big bowl with no habitat in it. Put some brush piles and humps in there between 4 and 8' deep at the base.
As far as stocking, the standard across the south is to stock 500 2-3" bluegill and 5 lbs of fathead minnows per acre in the spring. Many stock 300 bluegill and 200 redear instead, and that is usually what I recommend. In the fall you can add 50 4-6" bass and 100 4-6" channel catfish per acre. If you plan to feed the catfish, you can stock them the first spring, but if not I would wait until the fall.
There's a lot of other stuff to consider also, but I think this answers the questions you've already posed.
   / Digging a farm pond - need advice. #7
I dug a pond in a wet area of a field that is about 250' X 310' X 18 feet deep with an island in the middle. I was digging where there was a natural spring, but the spring alone would not have been nearly enough to fill the pond. I have approx. 18 acres of run off land to fill the lake besides what runs off of the gutters of my 60 X 80 pole barn and house that are drained into the pond.
As someone mentioned, I would also advise against having any shallow water if possible. I'd say that the average depth of my pond is around 8'. I wanted it deep enough to swim in and not have my feet hitting the mucky bottom. We stocked it with hundreds of fish 8 years ago and I can count on one hand the number of dead fish I've seen in the 8 years.
I live in an area where it is not uncommon to have zero precipitation for 4 month or more straight. If my pond was only 4' deep, it would be dry with fish baking in the sun by the end of some of our summers. According to my local DNR, it is common to have 2" of water evaporate a week during our summer months. Good luck.
   / Digging a farm pond - need advice. #8
CajunRider: Based on the size of the pond, you will be removing 13,000 cubic yards of dirt. The real question is, where will the dirt being removed from the pond go. The reason why I ask this question has to do with the most efficient and cost effective method of moving the dirt.
We base excavation production on the distance the soil has to be moved. Such as, a bulldozer in the size of a D6 to D7 range are cost effective up to moving soil less than 300 feet. The smaller the dozer the less effective it is and the shorter the distance it is considered productive. The cost to move soil with a D6 or D7 up to 300 feet is around the $2.75 to $3.50 per cubic yard.
If the distance is over 300 feet and the soil is not rocky, we move it with John Deere 9520 Tractors pulling two John Deere 1810E scrapers with a combined capacity of 36 cubic yards per load. This combination usually allows you to move soil in the $1.80 to $2.50 per cubic yard range depending on distance of travel.
My suggestion would be to rent a 150 hp tractor and a 10 cy scraper and do it yourself or hire someone with a scraper to do it. The bulldozer is effective in certain applications but is considered to be the most expensive method of mass excavation.
I getting a pro to do this for me. He has done many ponds. The dirt we removed will be used to build a pad for my house. He told me there are different configuration for ponds in my area (shallow in one end & deeper in another, 3ft deep ring around the edge for spawning area etc..). He told me to ask TBNers for advice.
As to filling the pond, I don't have to worry about it. My neighbor just got his pond dug and the pond just fills itself up to about 18" below the top. We figure that the spring rain will fill it up to the bank.
   / Digging a farm pond - need advice. #10
WVBartMan, you've obviously moved some dirt. I completely agree with you on the equipment needed. My issue was that I wanted the relatively steep drop to prevent vegetation. I ended up using an 800 series JD excavator and running 3 tandem axle dump trucks non-stop. Once dug, I then used an old Cat 955 high lift to crumb out the bottom and smooth things out and level the levee. I rented the excavator, owned the dozer, and owned one of the dump trucks and borrowed the other two.
With me running the excavator 12 hours a day and having my dad and two other buddies running the other dump trucks, I moved the biggest part of 18,000 cubic yards of dirt in just under a week. It ended up costing me under $1 per cubic yard to move the dirt. Being that some of the dirt was put 300 yards away from where it was dug, I figured that I came out pretty well on expense. My dad worked at a strip mine that had a dragline that had a 106 cubic yard bucket. He kept telling me that they move more dirt than I moved in half of a shift.
The worst part was blowing the hydro line right at the pump on the Cat with a bucket full of mud when I was using the bottom of the island bottom to help fill the bucket. Sitting in 6" of water and having no hydraulics, I had to fix it where it sat since it wouldn't back out and the one dump truck I had left wouldn't budge it. That sucked! /forums/images/graemlins/blush.gif
   / Digging a farm pond - need advice. #11
I had mine dug about the same size but odd shaped and a little deeper. The pic is 10 months after it was finished. The guy used a Komatsu D8 and JD790 excavator
moved about 1000yds 1000ft with 2 triaxles trucks for a building pad. the rest he piled up around the pond at my request.
The first three years of its existence were very dry and I eventually seeded the banks to prevent erosion, for the last two years it has stayed decent at 2-3 feet below spill over. Hopefully this year I can call it full. It only relies on ground water and rain.
I changed my mind /forums/images/graemlins/blush.gif on the barn location and in this pic he just got done stripping topsoil and moving the 1000yds about 400ft using the same excavator but now had an off road dump.
Total cost for both jobs came to about about a $.90/yard but we are talking 5 years ago and it was his part time job.
The slope is about 3:1 and My mononculture (right, wrong or indiff) of Large mouth are reproducing fine. I tried once to establish golden shiners as recommended by somebody but they did not take. I will try again this year.
   / Digging a farm pond - need advice. #12
You should have Goverment agencies able to advise you on the pond design and species of viable fish. May also think of a windmill for areation. Some floats for shade. Type of area and bottom material required for spawning.
No comments on the digging as it would sound like the fellow doing it knows his stuff.
Egon
   / Digging a farm pond - need advice. #13
Dargo: The dig and haul method is ideal and is still the preferred method on most projects. We started doing comparisons of the dig and haul verses the tractor and scraper combination, here is what we found as an example:
Fuel for One JD9520 pulling 2 scrapers at 18 cy capacity per scraper for a total of 36 cy per load operating 12 hours per day, 145 gallons @ $1.27 per gallon = $184 for fuel per shift.
Cost of the Equipment - JD9520 $215,000, JD1810E Scrapers @ $65,000 each for a combined total for tractor and two scrapers = $345,000
Cost to load & Haul = 1 Operator
My company got beat bad on a project 4-years ago by a company that used scrapers. When we visited the site while my competitor was doing the project we were amazed at what 6 men were doing and the production, 11,000 cy per shift. They had 4 JD 9400's tractors pulling 2 scrapers each, a JD 8420 with a box blade/roller combo keeping the haul roads dressed up allowing the 9400's to maintain one to two higher gears while transporting and a D10N working the fill area. The guy on the D10N was getting his tail worked off, he never stopped and stayed in high gear all day.
Needless to say we went a purchased some 9400's and scrapers to try and we have since increased the fleet of 9520's and scrapers considerably.
   / Digging a farm pond - need advice. #14
Cajun,
Here's a link some documents on Pond building and maintenance. It's for the Missouri area, but the pond building options are applicable to most areas. Check out the "Missouri Pond Handbook." Missouri Ponds
   / Digging a farm pond - need advice. #15
</font><font color="blue" class="small">( EddieWalker,
Sorry to be the bearer of bad news. I don't know who you were listening to over on Pondboss but they gave you some bad advice it sounds like. If you let me know some more details either here or in a PM, I'd be happy to give you some additional advice. )</font>
I've spent the last couple days trying to figure out the source of my information. At this time, I must confess to being clueless.
Please disregard my earlier post about pond depth and fish dying from the water turning over.
Eddie
Thanks everyone for your input. I really appreciate the advice. As for the depth of the pond, I am told by the local friends that if I go beyond 20ft I'll get to a sand strata that would allow salt water in the lake to invade my pond. I am also told that digging below 10ft is tough due to a large amount of water seeping in and the dirt would be slushy. Since I plan to use the clay I dig up for building my house pad, I don't want the slushy stuff. I think the depth of my pond would be 7-10ft depending on how much dirt I need for my house pad. Based on what I've learned about thermal inversion, I have nothing to worry about with a depth less than 10ft.
   / Digging a farm pond - need advice. #17
Unless you are happy with a pond like the muddy one down the road there is an axiom about the internet, free advice is worth what you pay for it and usually a lot less. So here's a little more dubious ;) info about how to build a farm pond
   / Digging a farm pond - need advice. #18
fishwiz,
You might wanna look at the dates of some of these posts. This particular one has been dead for over 5 yrs..
   / Digging a farm pond - need advice. #19
fishwiz,
Ah what's 5 yrs compared to the life of the planet :laughing:
2011 KOMATSU D65PX-16 CRAWLER DOZER (A60429)
2011 KOMATSU...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KBH 25T Tender (A56438)
KBH 25T Tender...
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
