Dimensions of 20hp Nortrac with FEL?
   / Dimensions of 20hp Nortrac with FEL? #1
davesisk
Platinum Member
Raleigh, NC USA
Massey-Ferguson MF 1220
Hi!
Can anyone tell me the length of the Nortrac/Jinma 20hp 4wd with the FEL attached? Is it over 10' long from the end of the 3PH to the front-most part of the FEL? I'm just curious if it will physically fit onto a 5x10 trailer (rated for 3500 lbs) and fit into a 12x12 storage shed (which would actually have inside dimensions of something like 11' x 11'.
Thx,
Dave
   / Dimensions of 20hp Nortrac with FEL? #2
If you go to the following site it should give you a pretty good idea of the length (although not the exact loader)
tractor outlet
Thanks, but I got the tractor's length from Nortrac's web-site, but I asking how much the loader adds to that. I didn't see it on this web-site either (or did I just overlook it?)
Thx,
Dave
   / Dimensions of 20hp Nortrac with FEL? #4
Dave,
I don't think it is going to fit. My JM284/ZL20 is over 12' from bucket edge to end of 3pt lower arms. Think it is about 12' 4". I park it on 12' planks, and it is over on both ends. I think the GB fel is a little smaller, and the 204 itself is slightly smaller than 284, but it is not a foot shorter overall. I think you could find a way around the trailer issue, but not the shed. Maybe someone will pipe in with the exact measurements. I am sure if you call them, someone would measure it for you.
   / Dimensions of 20hp Nortrac with FEL? #5
John is wrong, it will fit into the shead, unless the BACK WALL is aginst an impvable object /forums/images/graemlins/tongue.gif ya it is over the lenght by a bit I'm sure too, but like I said just lower the FEL and leave it in gear it will get in far enough to close the door!
Mark /forums/images/graemlins/crazy.gif
   / Dimensions of 20hp Nortrac with FEL? #6
Or you could back it in and leave the door open. RICHARD GAUTHIER
   / Dimensions of 20hp Nortrac with FEL? #7
I'm not in the office now or I'd go measure one for you. I'll be at a store either Saturday or Sunday. I'll measure one.
I used to have all the dimension on a chart for shipping, but can't seem to find it.
How tall is the door on that shed?
   / Dimensions of 20hp Nortrac with FEL? #8
For the record:
A NorTrac NT204C with a Great Bend 220 Loader is 11' 9" from tip of loader to the end of the sway bars in the up position.
   / Dimensions of 20hp Nortrac with FEL? #9
Doesn’t matter if it fits the tractors weighs more than your axel weight rating.
   / Dimensions of 20hp Nortrac with FEL? #10
If you scroll all the way down the dimensions with the loader attached are there also.
2019 Chevrolet Tahoe SUV (A49461)
2019 Chevrolet...
2014 VOLVO VN SERIES DAY CAB (A50854)
2014 VOLVO VN...
3in Poly Pipe (A49461)
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2011 JCB 541-70 TELESCOPIC FORKLIFT (A51242)
2011 JCB 541-70...
