/ Disc Harrow Selection For 18-45 Horsepower Tractors (Revision 2b)
#41
I have a 4 wd 4410 JD. I intend to disc up a section for a food plot. The section was tilled 2 years in a row 2 years ago but is now regrown with field grasses. It has been brush hogged. I know nothing about using a disc harrow. The soil I intend to disc is hard clay.
| John Deere 4410 Weight | 2,900 lbs 1315 kg |
| Max Drawbar: | 562 lbs 254 kg |
| Max front axle: | 1,588 lbs 720 kg |
| Max rear axle: | 4,410 lbs 2000 kg |
| Dimensions | |
| Wheelbase: | 68 inches 172 cm |
| Length: | 117 inches 297 cm |
| Width: | 50 inches 127 cm |
| Ground clearance: | 13.4 inches 34 cm |
| Mechanical | |
| Chassis: | 4x4 MFWD 4WD |
| John Deere 4410 Power | |
| Engine (gross): | 34.6 hp 25.8 kW |
If you get a medium or heavy duty box frame Howse, 18” cutter head, it will cut, due to the weight, the old ones are very heavy.
| Shipping Weight | 650.pounds |
| Width | 66.1 inches 167 cm |
| Massey Ferguson 1547 Weight |
| ROPS | 3597 lbs 1631 kg |
| Cab | 3957 lbs 1794 kg |
| Max capacity | 8378 lbs 3800 kg |
| Max front axle | 4630 lbs 2100 kg |
| Max rear axle | 4630 lbs 2100 kg |
monroetufline.com
monroetufline.com
