Disc Harrow
   / Disc Harrow #11
</font><font color="blue" class="small">( will have to be very heavy with lots of horse power in front of it. Like 200 or more )</font>
I've found a good 12' pull type dis cweighing a couple thousand pounds behind a 90hp tractor will turn sod over pretty good... course.. a 17' or 24' and 200hp machine does it in half the time!
Soundguy
   / Disc Harrow #12
New Holland data.
Note the working depth and HP per foot listed.
Egon
   / Disc Harrow #13
Uh... yeah.. looks about like I said.
The numbers look like a 12' is fine on a 90ish hp tractor... etc...
Soundguy
   / Disc Harrow #14
So if I was looking to tiller some clay for the first time..would I use a tiller...This is what I have been looking for recently. Hopefully I am looking for the correct peice of equipment. I am planning to turn the area that is currently weeds into a garden area.
   / Disc Harrow #16
For a garden area a rotatiller should work fine. I know my B7100 will not be able to pull a disc that would do an acceptable job breaking fresh ground.
Egon /forums/images/graemlins/grin.gif
   / Disc Harrow #17
</font><font color="blue" class="small">( Perhaps - yes I did err. Discs can turn sod but it will have to be very heavy with lots of horse power in front of it. Like 200 or more. This is equipment usually is not owned by members of this board.
This would be an excellent breaking disc.
Egon /forums/images/graemlins/grin.gif )</font>]
I don't think I could pull that with anything smaller than a D8, and bigger would be better. /forums/images/graemlins/crazy.gif
A single row cultivator usually has multiple holes to adjust the shovels. Filling all the holes with s tines ought to make a small version of Ken Sweet's monster. /forums/images/graemlins/wink.gif
   / Disc Harrow #18
Will finish up a foodplot this weekend. Method was brush hog, Roundup, using an implement almost identical to the one shown by Ken Sweet and than disking. The spring loaded S-tine tiller works great behind my JD4600. Pulls basketball+ sized rocks right out of my sandy loam and just pops back and resets on the bigg'ns. These have to be dealt with by digging around with the pallet forks on the FEL. Working things up, letting it rain and coming back later for a few more passes helps too. Good luck with yours.
   / Disc Harrow #19
</font><font color="blue" class="small">( Yep - but your not turning over sod at the depth listed.
)</font>
whoops!, my bad.. Very true.. fast reading.. I missed what you were trying to say, bout the depth vs turning sod.
When i disc.. if there is sod.. I figure one pass just to cut it up.. no depth achieved.. etc.. then sucessive passes to actually get discing done.
Could plow it.. but then.. I've only got a 2-bottom.. and that would take all day..
Soundguy
   / Disc Harrow #20
What about a spike-tooth harrow. May be a good alternative.
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2018 JOHN DEERE 50G EXCAVATOR (A51246)
2018 JOHN DEERE...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
2011 KOMATSU PC56-7 EXCAVATOR (A51246)
2011 KOMATSU...
2023 John Deere 8R410 MFWD Tractor (A53472)
2023 John Deere...
